What amp and which Subs should I get?
Guest 02cougarc2
Hi, I have a 2002 Mercury Cougar and just put in my Pioneer Premier DEH-P580mp headunit(50x4). I have narrowed my sub woofer search to these two,(http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/3135029/vpcsid/0/SFV/30046) and (http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/3135028/vpcsid/0/SFV/30046)...the only difference between the two is the D2 and D4 which I have no idea what that means....im thinkin somethin to do with ohms but Im not positive. If you guys could tell me which I need, that would be awesome. As for an amp, I dont kno what kind I need and how much power given my head unit and the pioneer subs. I would also like to replace the four(4) stock 4x6's with some 5x7's or 6x8's so I dont know whether that changes what I need. I know this is alot and i probably sound like some annoying stereo rookie but im just confused as crap. Thanks For Your Time
EDIT....Current door speakers are 5x7, not 4x6...sorry
Edited by 02cougarc2
Decent choice there guy...a dual 2ohm sub can be wired to 1ohm or 4ohm...a dual 4ohm sub can be wired to 2ohm or 8ohm.....visual example here....
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=3
With the 350 watt rms power handling your most likely gonna wanna find an amp that does this @2ohm...meaning you should go with the Dual4ohm version...now as far as a amp goes i think this will suit you....... http://cgi.ebay.com/CRUNCH-PZi1000-1-CLASS...id=p4999.c0.m14
Decent price and does rated..got the 1500 watt version for the wife and it's reliable....if you get the dual 4 version you can wire it to 2ohms and get 500 watt rms(which will give you a little headroom) just set your gains properly...any more questions just let me know!
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
Guest 02cougarc2
budget wise i dont want to spent more than 300 and thats with subs, amp and install and as far as what I want, somethen thats gonna sound really good but still be able to hit like heck
thank you SO much man but I have to say im throrroughly confused on the amp....so go with the D4?
Yes...if you have your mind set on that sub go Dual 4 to match up nicely with that mentioned amp...nice little first budget build...then later if you wanna upgrade your sub, get a dual 2ohm sub,and use your amp to it's full potential by wiring it to 1ohm!
Guest 02cougarc2
would either of these amps work?
http://houston.craigslist.org/ele/1366894878.html
http://houston.craigslist.org/ele/1360471243.html
Hey guys....I found this pyramid 4000 watt amp for 100 bucks(link below). Ive heard it before in my friends Tiburon with 2 Type R 10's and it sounded awesome.... Should I pursue getting it?
Heres the link
http://houston.craigslist.org/pts/1393046950.html
NO!!!!! Don't do that...that's worse off than the BAMF!!!!!!!!!!!!!
