This question has probably been asked somewhere, but here it goes. If the gain and bass boost is maxed out on an amp, the volume set at 75%, deck eq bass flat, and there is no audible distortion and niether the amp or subs heat up, can there still be clipping happening. This is how a friends ride is setup and he bangs hours at a time with no problems. Opinions?
Sorry for the long question :)
SMD Super Seller
My Feedback Thread
Absolutely. Your ears aren't nearly as accurate as a scope or volt meter.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
if gain and basss boost are maxed it is clipping .
Most people cant hear even heavy clipping.
They can hear their subs crying, but that is wayyyyyyyyyy too far already.
Grab a scope and check the wave.
If its not clipping with deck flat at 75% with gains 100% and bass boost 100% Ill paypal you 25.00
You wouldn't think so, but his shit sounds good, Damn good. I'll try to get my hands on a scope and hopefully make $25 Lol:nea:
SMD Super Seller
My Feedback Thread
Depends on hopw bad its clipping.
U said it sounds ok, but could still be clipping just a little.
Unless its a hard clip[, which would make the speakers sound bad..the amp should be ok.
The speaker would be the first to fail, because of clipping.
But if it's only a slight clip, it might take it forever.
I would say that unless you have set the amp/deck up with a scope..prob, 95% of the population has a slight clip.
Im good, but even I cant tell the very beginning of a clip.
Can I hear it before most people?? Yes, but thats when it's already audible. A clip starts way before it is actually audible.
what kind of head unit is he running? it may be because he has shitty preout voltage... hell what amp and subs is he running? and what do the other settings look like... lowpass, subsonic?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
