How Many Run Just One Woofer Setups
MrSoundz
I run a single t2 15 setup and its gets very loud, louder than most dual setups locally, but I'm in a small town.:)...I always prefer to run a single woofer setup because it's always more impressive with one.;)
1997 Lexus ES300
HU - Pioneer MVH 7350
Processor - Helix DSP
Front Stage - JBL P660C
Mid/high amp - Alpine PDX-F4
Subs - 1 IA Death Penalty 12
Sub Amp - Cactus Sounds PF300.1
something called the rule of 3, for audio people... if you double what you have.. cone area and power you only gain 3 db. therefore single sub on proper power in proper box can get louder than 2 or aound the same. onlt reason im running 2 is because they were by 1 get 1 free! couldnt pass that up on $500 mspr woofers!
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
I run 1 RE XXX 12 of a US Amps AX2000, and I love it!!!
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
i run a single sub set up right now. much more cost effective lol
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
I run one dreadnaut 15 on a planet audio vx2200D It's very loud for one 15 and everyone that has sat in the car agreed
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
I love my 1 12, people are amazed when i tell them its only 1 sub. I get props from everybody at my local shops here in town And im always down for a demo. Last I hit was 142.1 @ about 40 hz (forgot to check), I think ill gain more because the sub was still stiff as hell when i ran it.
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
Like Jacob said I have also tried going to one from two woofers and found higher scores on Termlab. I have sold two of four 15's and am going to run 2 15's giving me more airspace in the box and better effiecent use of the power that I have. I am fully convinced that less woofer and more power and box will turn better numbers in some situations.
Like Jacob said I have also tried going to one from two woofers and found higher scores on Termlab. I have sold two of four 15's and am going to run 2 15's giving me more airspace in the box and better effiecent use of the power that I have.I am fully convinced that less woofer and more power and box will turn better numbers in some situations.
That is a very true statement, so no need to be convinced lol.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
