DC Sound Lab
I think that I have my heart set on an AQ 1200D. I'm also really liking the DC Level 3's. I want to run 2 10's, but only plan on running a single 10" for a while (I've already got the enclosure for a single 10"). I was thinking of going with a dual 4 ohm Level 3, that way when I get a second one I can run them at 1 ohm off the 1200D (I did figure that correctly, didn't I?).
Anyway, will the Level 3 take the 870 watts that the 1200D is rated at for 2 ohms? This will be in a daily driver.
Dan
It should as long as you properly set the gains.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
x2 just be carefull not to push too too hard and d4 coils will be right for that 1ohm your needing
Shouldnt have a problem unless you crank the sh*t out of the gain
-Drew
uhoh_45 said:
4 level 3 10s with level 4 coils and extra spiders on 2 audiopipe ap30001ds at 2 ohm.... 6k to them.. no problems! :D i just dont crank it all the time unless its a good song or a demo but they do not get warm
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i set each amp for 77V at 2 ohm which is 3K soo when i have it up at 28 ( where i set it at) they take it but oviosly wont for long periods of time i have yet to get them stinky or warm so or even bottom them out
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
it should be fine at 850 rms, im running my 1 15 off 1300 rms (gains over half) daily so it shouldnt hurt it at all,
1998 4dr blazer
Alpine CDA 9884 head unit
DC lvl 3 15"
3.7 CU FT box (without displacement) tuned to 36.9
1/0 welding cable
Sundown Sae-1000D at 1 ohm
Kicker 4x6 mids and highs in dash
Hifonics Zeus 6.5 mids and highs in front doors
Well, I'm getting an MTX RFL600D (thanks, tech2332). So if I decide to go with the Level 3, which I'm pretty sure I will, then I should be fine. I'll run it sealed for a while, then probably get a nice ported box made.
Dan
