the subs he has are the rockford trf. You still runnin the 12's or did you find some 15's?
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
It's the same 12's, I found the .5 db when the battery finally got charged back up.
It's all on a stock alt so not a lot to back it up.
Question on db drag does the car stay started?
I think I am in the SS 1-2 class but really have no clue.
3 or 4 batterys will be the next upgrade I shoot for.
you have 8k watts and no alt to back it up? wooo weee. how often do you run through alts and batts?
Actually were working on a plan to fit 3 2400's in the hatch and one in the front. I have a alt just haven't installed it.
Theres a show on sunday and thats gona take some time to get that all figured out.
I coulda just popped the 2 T2001 in but figured why not give these T4001 a shot!
Just got another CRX but it's a Si with a sunroof.
Between working on it, my house, and just making sure I show up for the next event keeps a basshead busy!
Not to mention future upgrades!!!
if you dont want to blow your amps, i wouldnt turn on your amps till you get some power in there.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Definately put your new alt in first man! It will make a WORLD of difference, & I wouldn't run your bigger amps until you do.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
you're running 1/0 all around and to your amps? maybe more runs to your ground spot? and make sure wires to the amp are short as possible.
refs: chode69, superduper
I'd say for sure he has to be. ANYTHING less, & he would have a fire from the 300amp current draw on each of those T4000.1BD's
Having only one battery & no HO alt is without a doubt his problem.
Edited by Chris
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
