So I finally got my alt installed in my 98 honda civic.I started the car up and car isnt charging at 14.3 its 12.1.So i checked each batt in rear and under hood and same.I checked all fuses and blew my batt 80 amp fuse.The next day i replaced it and still the same thing what else could it be.
Could possibly have a bad harness like I had...did it ever charge? Your running off the batt if it stays at 12 so I wouldn't run it that long.
2003 Chevy Trailblazer LTZ
Pioneer 980BT
16 SA-10's - 4th Order Bandpass
NS-1 - 3 D3100's
DC & XS Power, Audio Technix, Sound Deadener Showdown
Team Sundown Audio
I just did some research and found out that My original power wire from my alt to batt is fused at 80 amps.I then read that If i leave that and just upgrade my wire and have it directly to the batt it will help cause its fused in the fuse box instead i will just do a 1/0 guage run.But why is it that when i check the terminal on the alt and ground some where with the dmm it only reads 12.1
Edited by jdmferio13
big 3 upgrade check all your wiring to make sure its not shorting out
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Well I found out the fuse blew cause i shorted it out fogot to unhook back battery.So back to where I started.The alt is in and seems to be running fine.I had it checked on a macine he said it was fine.So then I installed it hooked up power wire and clipped in side plug, turned it on and its not charging.I dont know
bad ground possibly?
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
