the4stringking Posted October 19, 2009 Report Posted October 19, 2009 I have a 2002 camry le with an inline 4 engine and stock alt and battery. I don't want to change the alternator (I know), so I was wondering what would be the best battery I could get for my system. (I'm using an arc 1500dr which puts out about 1000 rms at 2 (not with my electrical) and a 2 channel re amp powering 4 speakers 200 rms watts total. I have already done the big three. What would be the best battery to replace the stock one with under these circumstances? I think my alternator is either 90 or 100 amps and my battery is size code 35 or something like that. Old setup 2002 Camry LE Fi Q 12" BP power in a 2.3 cu box tuned to 28 hz Alpine MRP-1000 JVC Deck RE 800.2 speaker amp RE Coax 6x9's in front doors and Deck Alpine Type S 6.5's in trunk now... 2006 Subaru Legacy 2.5i Special Edition JVC KDX double din 1 Run of Knu Konceptz 1/0 Big 3 Waiting to get Amp and sub(s) and speakers
Guest DC Power Kyle Posted October 20, 2009 Report Posted October 20, 2009 I believe you can fix a D2400 in there
MECHMAN Posted October 20, 2009 Report Posted October 20, 2009 A D5100 will for sure fit without modification, but you may be able to go bigger 1-888-MECHMAN www.Mechman.com [email protected]
the4stringking Posted October 20, 2009 Author Report Posted October 20, 2009 These are all kinda outta my price range. Anything at 200 dollars or less? I'm in college I has no monies Old setup 2002 Camry LE Fi Q 12" BP power in a 2.3 cu box tuned to 28 hz Alpine MRP-1000 JVC Deck RE 800.2 speaker amp RE Coax 6x9's in front doors and Deck Alpine Type S 6.5's in trunk now... 2006 Subaru Legacy 2.5i Special Edition JVC KDX double din 1 Run of Knu Konceptz 1/0 Big 3 Waiting to get Amp and sub(s) and speakers
Tebo Posted October 21, 2009 Report Posted October 21, 2009 These are all kinda outta my price range.Anything at 200 dollars or less? I'm in college I has no monies optima yellow top should do you around 200$ Im running right around 1000w rms on an optima and no big 3(yet) If i fully power my rears the 4 channel will cut out from time to time. Now that I think about it you might want to get something a tad bigger than the optima. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
soundzright Posted October 21, 2009 Report Posted October 21, 2009 kinetik 1200 or look into deka intimidators.
