Good Setup?
I was wondering if this was a good subwoofer amp combo. i was thinkin of 2 Kicker 15'' L7's and a Hifonics BXi 2010D. because my friend has 2 15'' L5's with i think the hifonics BXi 1610D in an expedition and on 8 they hit hard with the remote bass not turned even half way up.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
anybody want to help me out here
decent subs low quality amp (decent means ok, not the best but tolerable)
if it is what you want go ahead
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
nefew has a 2005brutus on 2 l7s sounds good he is tunned low around 33hz it is in a 9 cf box
we had them in a 12 cf box for the 2 sounded even louder
hes beeen haveing it about 3 years still kickin
what would be a good set of 2 15's and a good amp for them for maybe a little over $1000
AQ 2200D and 2 HD312's the subs are 250 each amp is 350 so roughly 850 that with def slam the lows :P
oh sorry you said 15's well the 15's are 270 each so about 900 then.. but even better :P
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
I have the Hifonics BXI 2610D hooked up to my 2 15" L7s, they are taking it pretty good. You will be good with the 2010D, but if you want to push it to the max, then go with the 2610D. I used to have the 2010D hooked up to them, and switched to a 2610D and noticed a slight difference. These amps are good for people with a small budget. If you have the money, I say you get a better amp, but don't get me wrong, these amps are pretty good. I like them.
AQ 2200D + 2 15" L7s + HUGE box would be a nice combo... With the correct box setup you won't be dissapointed with the results.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
on the audioques should i get Dual 1 or Dual 2 if i get the aq2200d
