I'm not looking to compete any time real soon, and I actually like the sound of a somewhat underpowered sub. I believe my amp is benched between 1400 and 1500 watts, and I was considering power a 12" BTL off of it. How well would that work? Or do you need quite a bit more power to get it going?
I want to get a BTL over a BL because if I decide to upgrade amps, I'd have that extra room without having to switch out for a new sub.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Seeing as it's underpowered already, I wasn't going to. But I might get the cooling and some of the others so that I can throw 3k watts at it later on. I'm going to be driving a civic, so a single sub setup is probably in my future.
How is the SQ on the BTL's? I really want to get something with real nice response, not sloppy at all. I plan on putting it in a 2 cu ft net, ported at 35 hz, aimed forward/sealed off from the trunk. The ports will effectively be external ports. (you'll see when I start building it)
Subwoofer Wall
i like the sound of mine. it gets low and clean. its hard to believe the btl is considered a spl sub when it sounds so good.
just don't get the third magnet if you are going to underpower it.
i love my btl's.
ya man 1 sub in these small civics is enough. Not alot of room, but the small cabin helps wit the loudness.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
Man, you won't be disappointed if you go that route. My 2 18's take over 2000 a piece every day without even blinking and all I have is the X-max and 3rd magnet. The Quality of sound is really good too, rap through jazz through oldies up to metal all sound pretty incredible.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
