man i tell ya its always something.
well my alt is making funny noises and my lights are starting to flicker. my volt gauge fluctuates (never below 12). are the brushes in my alt going bad or something?
Eclipse cd7000
Any belt slipping? Sounds like the alt could be indeed going out...
You dont have much luck..
Hard to tell. Would have to look inside.
mannn wtf....the alt is less than 6 months old. everything hooked up to it is 1/0....
Eclipse cd7000
guess its time to send it out to mechman.
fuck...
Eclipse cd7000
I have the same problem. all my lights flicker and my voltage meter goes up and down but never a difference greater than .5 volts and alternator does make funny noises.when i accelerate the meter goes back to normal. but when i put a load on the alternator the flickering goes away... do i have the same problem. oh and yea the meter problem goes away when a load is put on as well.
yea maybe were seeing the same problem here. faulty regulator maybe? I drove it last night for about 30 mins and the lights were still flickering. My frined put a dmm on it and it reads between 14-14.8 volts fluctuating a lot inbetween. Idle it starts dropping bad...even when no significant load is applied. The only real bad part about this is the time it takes to take the alt out in my car....its a real bish in my car.
what kind of alt do u have?
Eclipse cd7000
It most likely the regulator the regulator went out in the stock alt on my dad's '05 trailblazer....his was doing the same thing except going from 14v to 18v up down very quickly.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
i have a stinger one bought from my local audio shop. this is gonna be funny but i bought it for 800 and been having a lot of trouble with them so i think im going to buy one from dc and get my money back because i think this shop likes to screw a lot of people over.
also i noticed this when my alternator makes funny noises like when its turning my lights flicker on sequence with it so im sure it has to be the alternator.
opinions on what i am dealing with and what i should do?
Sorry for thread jacking just thought we had the same problem so i decided to not just make a new thread.
im all stock with a 105 ah battery with 4g
my volts never drop under 13.5 and i have a 14.5 volts for most of the tym
but at like 800-1k rpm a few bass notes hit then the system trys 2 shut off then comes back and it dose that a few tyms
can any one exp. this and with the amps on my light still dim like there is a huge bass note
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
  • Who's Online   0 Members, 0 Anonymous, 2848 Guests (See full list)
