What Could Be The Problem!?
mtxcivic07
I have an MTX 7801 amp that i had to send back to them to get repaired. my problem was after about every 20 mins or so of playing it would overheat and the thermal light would come on. I have a Kinetik hc800 wired in parallel with a regular acid battery under the hood. stock 135 amp alternator. 3 JL w3v3-4 subs wired at 1.33 ohms. what could be causing the overheating??
18's in a wall to come....Its not all about the posts....check the member #...
Isn't that the amp that had one of the capacitors on the inside break off?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
i would hope your not playin the amp with caps missin
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
lmfao.
Gota have my rear view shakin and my seats vibratin'.
(2) 12" Diamond D3
(1) DEI Directed Audio 2400D
(1) Kicker L5 15"
(1) Rockford Fosgate P5002
(2) 12" Fosgate P2's
(2) 15" Fosgate P2
^^Not all hooked up at once, i rotate. Its all i got.^^
hell no im not playing it with those caps missing. I got it repaired and was working fine. Amp just overheats way too often. It has a constant 12.5-14.4 voltage going to it. It might be the ohm load thing, but it should be wired to 1.33 ohms b/c that is what (3) single 4-ohm voice coil subs wired in parallel gives you.
BTW... the subs are wired with 10 gauge speaker wire... All of the subs have their own + and - wire coming through the back of the box and all are wired directly to the amp's + and -
  • Who's Online   1 Member, 0 Anonymous, 1689 Guests (See full list)
