was thinking about it. never got a response from him yet.
they are good amps no doubt as long as you be easy on them and watch them.
not an amp that i trust to just hook up and throw in a tight spot and never check on. if that makes sense. B)
to be honest, i don't know 100 percent which one they are.
i do believe they are the original z1 though, before the z1a or b.
regular z1 not a or b
mine was benched at 4977 at .7 on a 12volt system
it does get hot and shuts off in the summer but amp also has no cooling other than heatsink if you add a fan it should help alot I ran mine at .35 daily for 3 weeks no problems
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Model Input Sensitivity Tested Voltage Power @ 4 ohm/ ch Power @ 1 ohm/ch Dimensions- cm Dimensions- Inches Shipping Weight
The Z1:
Z1................0.2V - 6V......................14.4.................750 W......................3000 W................61 L x 30 W x 6.6 H.....24 L x 11.75 W x 2.625 H...35 lbs
The Z1A:
Z1a..............0.2V - 8V......................14.4.................1250 W.....................5000 W...............68.5 L x 30.4 W x 7 H...27 L x 12 W x 2.76 H.........43 lbs
I wouldnt buy a Z1 in new condition and never taken out of the box, let alone used condition.
As for a Z1 doing 49XX watts at .7ohm on 12volts, I dont see happening, must of been a Z1a? Because the z1 only does 5krms on 16volts.
Besides from the differences in wattage, there is a difference in weight and size. Just another way to tell them apart.
As for a Z1B, there was rumors of replacing the z1a with the b, but I dont think it ever happended and became a z2 prior of DD having the z2lv and the z2hv
http://www.ddaudio.com/dd/amparchive.asp
Edit: Another easily way to tell the z1 and the z1a apart is the terminal cups for your power speaker wires.
The z1 had black plastic terminals, while the z1a had gold plated terminals under clear plastic.
Edited by Bangin Caddy
its NOT a zenon board so dont give false information
I believe one of the three Models is a zenon board buddy.
Team Bass-Hz
id wait for the saz4500 better efficency and my buddy runs a 3000 at .5 ohms all day. the z1 is only 76% efficent :hairtrick: :hairtrick: :hairtrick:
dc 12k
2 ascendant mayhem 12s
xs power 200 amp alt
2 odyessy pc 2150
dc audio 175 x 4
scosche wires
stinger inter connects
12 volt customs 175 amp alt
pioneer avhp 4100 dvd
arc audio eq
cdt 6.5 components
152.8 db drag
street c
http://www.dcsoundlab.com/
//www.dcsoundlab.com/images/header.jpg
