or for free..... u can just cut the wire to fit
u dont even have to mash it in there... cut it so it fits easily into the terminal but is snug
1/2" of a reduction in 1/0 to 4g isnt going to matter at all voltage wise.... hell a reducer is worse because it only creates two contact points whereas nearly stuffing the terminal with wire then a screw down creates alot more surface area for contact
distro blocks cost money
heatshrink cost money
reducers cost money
trimming wire to fit priceless
x2 this, i dont know why people are giving you options that you dont need.
cut to fit...best Idear..cheapest as well....
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
I shoved all i could with a flayhead sfrewdriver. I alao wtapped tje reducer in black elec tape to thy could not touch.
WTF? :blink::blink::blink:
2001 chevy blazer xtreme
my blazer xtreme build
On top of all that, my little sister is marrying a real fuckin winner tomorrow
I've gotten that much wood just viewing this thread. :blush:
reducers cost money
x 2.5
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
I've seen guys use bolts and ring terminals to reduce their wire. Basically they just use a ring terminal on the end of the wire than took a bolt that would fit into the amp and put it through the ring terminal and than used a couple of nuts to hold them together. With that done they than bent the bolts so that they wouldn't touch and presto you problem is solved.
The Shoe Maker without shoes!
  • Who's Online   1 Member, 0 Anonymous, 1128 Guests (See full list)
