Alright, this enclosure will be for Scapelli's pair of 12's which will most likely be Nightshades iirc.
Specs come to:
-4.3 cubes net
-6" aero port
-30hz tuning :)
Got a bit done tonight, pieces cut and edges of the side panels rabbeted for ease of carpeting later..
Back on..
Side on..
More as it happens
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Why only a single 6" port? I don't agree with that at all. The least amount of port area I would have went with would have been 4 4" ports. Trust me as I am speaking from experience that a single 6 will not let those sub show their full potential. I am just trying to help is all, not trying to cause any issues what so ever.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Because this is all of the space he has and it's darn close to 7 sq inches of port per cube, which is a ratio many people use for aero port area...and anymore port area and it couldnt be tuned low at all due to length constraints for the port(s), which was his main goal (to tune low)
Edited by Pioneer~Saturn
Team Tupperware
More tomorrow
Team Tupperware
looks good so far man
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
Thanks
I'll have the port a bit later today and hoping to have this structurally done by tonight
Team Tupperware
Mo' picz..
Team Tupperware
Resin..
Just need to clean it up a bit and get it carpeted and then the exterior pieces of the port will go in..more tomorrow night
Team Tupperware
