Posted (edited)
hello all, not sure if this is the right place, but here goes
i wanna change it up a bit. i have 2x Treo SSi 12.44 in a 3.6 cf box @ 28 hertz. I wanna do a crx style box (with subs up and port forward).
sub here:
http://treoonline.com/infosheets/ssi_subwoofers.pdf
going into an '02 Envoy
box:
44" wide x 23" long (about) x 16" tall
double baffle, with flush mount
i dont want to go taller. and i dont know if i wanna go into aero port territory.
MAY03LT said i should check out SMD.
Edited by Gavinvoy
Glad you made it over here. :8)
i dread the moments when i have to ask a question on ca.com, full of trolls and haters. i dont frequent RoE anymore, and since Fallen left, i dont have an enclosure guy .... hopefully someone here can help me out.
when did fallen leave?
i did a single 5" aero port, 15" long. 14Hx37Wx18D = 3.816cuft @ 28.1hz
krannyman...the randomness of your avatars never ceases to amaze me lol
i can tinker with a design for you, but i *need* to get some homework done asap, so i'm going to tackle that first. someone else may chime in by then, but if not i'll do what i can
welcome btw :)
Posted (edited)
No such thing as a 5" aeroport, so...... For 3.8 cubes I would reccomend that you use 3 4" ports to get enough port area for that size box.
Also for the guy that asked the question about the box I don't reccomend doing subs up and port foward at all. You should do subs up port back or even subs back port up, but not port foward with subs up ever.
Edited by Nightshade
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
haha thanks bro i try.
he left last year. May was saying he might be back after the new year.
your avatar looks like my neighbors :D
he still posts on RoE pretty often. he doesnt do designs since he was doing his finals or something like that as of recently. havent heard any changes about it.
and lmao
Forward means towards the front of the car... and a CRX box is subs forward ports back now :)
Subs up port back should work well enough although with only 2 12's you might want to consider subs back port back.
Is this for a burp box?
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
