Tripleb45 Start up kit (not a build)
tripleb45
I like the ideas that you have thus far.
Do you plan on gettin more of those hifonics or do you plan on sellin them and gettin somethin bigger.
What kind of power to you plan on givin those btl's?
Maybe you could run 2 high powered amps to save on space. Like 2 4ks or somethin?
Pickup an alt or 2. If you dont mind cuttin your truck up, you could use meades spot for some batts. look for some used ones.
I would keep the HU cuz it works and is not necessary to upgrade yet.
As for speakers, the 6.5s sound like a good idea. I'd worry about the drive and passenger door first and worry about the back later.
Idk, just thought I would spit out some ideas off the top of the dome. Dont let the other peeps on here bring you down.
Good luck on your build man!
Dam thanks people think that talking ish is funny and look like dam fools. I appreciate that. I am thinking on the amps I dont know. I plan on giving them maybe 3000 to 3500 watts daily. I am thinking about 2 alts. I have already started on the back doors so the front and passenger should go next. I just figured since this is my first time fiberglassing I should start with the less important doors first. I dont know about the meade idea now I am still thinking. Thanks for the positive. People see one jackass act a fool, think its funny, and do the same thing. Now if someone did it to them they would be pissed, but what goes around comes around. lol
I feel ya on that one and I am confused on the coax in the rear, but I am going for balance so I may just run 4 in the front too.
Well coax are basically full range speakers and you can't tune it to sound how you want aside from the horrible EQ on the h/u
I sold that Hu and will edit that now. So with a better HU I can right?
So you're saying that you wanna run between 3000-3500w per woofer... What kind of budget are you setting aside for that power and the electrical to back it up?? If you can post up that number I/we can help u out with sum choices and finding quality product for the best price.
Also if you have any questions about glassing just drop me a PM and I can help u out.
Pioneer AVIC-N2
Ok I will do about $5500 and if I need more I will put that in the budget. Could someone write me up a decent list with this budget? I want to run sundown amps
I wish I could help u with that. I'm a noob, but I just wanted to give u my .02 of support! I'm gonna be starting my t-line build over break and then school and I was worried about the stupid people on here that just put others down (not the majority, but there still are some). I give you kudos for starting a new thread :)
if you have the extra 50ish bucks you should build a t-line in the mean-time and plop a sub in there. theyre fun and get your brain thinking. plus, you can have some boom in the back while you wait for your babies to get re-coned :)
keep on glassing boy. ;)
Rowan University Electrical Engineering
LINK TO MY BUILDDDDD
Current Setup in my 00' Hyundai Accent:
Pioneer DEH-P6900UB
RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS
Eclipse SE 6500 (6.5 coax in rear deck)
two Kicker C124's in a t-line tuned to 28.6Hz
Kenwood KAC-7204
US amps 1600.4 V2
Upcoming Build this summer:
T-Line enclosure for two C124's tuned to 28ish hz O_O
amp my speakers with a US amps 1600.4.
Second Skin Should be fun ^_^
Sundown does make great quality amps but any reason why you've ruled out all of the others??
If you wanna go with new amps then - 4 Sundown SAZ-3500Ds or used 4 SAZ-3000Ds(would save a ton of money this way). The BTLs can handle that power daily so long as the amps are setup correctly, correct enclosure, etc.
Electrical(I would suggest more but this IMO is keeping it to a minimum) - (2) 300a+ alts (*Ohio Gen/DC Power/Mechman/Irraggi/XS/ etc).... (6) *Northstar NSB-125s/XS 3100s/etc similar permance batts... (2) Power/ground runs per amp(*2/0 Ultraflex welding wire, 1/0 Kicker hyperflex, Knu Kollosus flex, Stinger Pro, etc).
Those would just be the big parts of the electrical setup, still would need to account for fuses/fuse holders/batt terminal/buss bars/lugs/etc other accessories. Honestly between amps and a proper electrical setup $5500 is really gonna cut it close unless you're buying almost everything used.
Pioneer AVIC-N2
Maybe SOME but you need some sort of external eq but they are not expensive anyway. You could probably get a pretty good one for around $40 if you look. And the amps I think doing the 3500's would be best because if the full 3500 was too much you could still turn the settings down and run them very efficiently and get a super clean signal ;) and if you do turn them down daily you can have a little extra there for when you compete! Well damn get the 4500's then =D
5500 for everything? I dont see it happening.
dual alts and kit. 12-1400
batteries 300x8 2400
buss bars fuses wiring etc 600
you are at 42-4400 alone right there and trust me thats on the cheap side. that leaves you a grand for 14000 watts. It just can't happen. playing big is retarded expensive.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dont necessarily know what t T like is but that sounds decent, and dont give the jealous ones too much attention. Some people feel that it is funny to act an azz and want followers to laugh with them but they ultimately look dumb as hell. But I CAN'T WAIT TIL MY SUBS GET HERE.
I am looking to aim at spending $5500 but that doesn't mean that I can't do a little more, I just dont want to. lol I chose sundown because I want 4 great quality 3000 watt amps that do rated power and doesn't blow when that power is reached. lol and I have been hearing a lot about Sundown. I think I am aiming for the saz 3000's more than the saz 3500. What amps do you have in mind that can do rated and are 3000 watts rms at one ohm?
I think I will go with the 3000's unless I find a good deal with the 3500's lol
$5500 is not my final price I am aiming to spend only $5500 if I need more I will add more. Hopefully not.
  • Who's Online   0 Members, 0 Anonymous, 746 Guests (See full list)
