Battery Question.. is this a good deal?
Here are the specs of this battery
Specification
* Ah 93
* 12V 350 Watts / Cell @ 15 Min Rate
* Dimensions(inches): 12.04 long x 6.83 deep x 8.06 high
* Weight: 67.4 lbs / 30.5 Kg
* 10 year design life @ 25C
* Terminal: Inserted, thermal copper alloy insert
Features
* Absorbent Glass Mat (AGM) technology.
* 3 Year Warranty (refer Dynasty warranty car, 41-9026)
* Patented Long Life Alloy.
* Patened UL Recognized Flame-arresting vents in each cell for safety and long life.
* Designed with the same recombination, thermal runaway prevention, gassing and flame retardant characteristics of the Bellcore 4228 compliant Dynasty Telecom products.
* Flame Retardent case and cover compliant with UL 1778
* Termally Welded Case to cover bond
* Not restricted for most surface, air or water transport.
How do you determine the Watts of a battery?
What is more important in a battery?
1. Ah
2. Cranking amps
3. Watts
^^^ can you put those three in order of importance.
if I was to take a guess at it I would say
1. Watts
2. Ah
3. Cranking amps
Finally would this particular battery be good for car audio? I am only going on the fact that it is a 93Ah battery.
Ah is good to determine extended constant drain on the battery. this is a good daily jam session rating
6 cells so you can figure watts
cranking power is a burst rating not really useful for daily. more suitable for a burp tho
6 cells x 350 = 2100 watts
93ah
83.00 and free shipping sounds like a good deal on this battery.
Well it says open box which is a nice way of saying USED. I wouldn't touch it.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Comes with 1 year warranty... still you would not try it?
well i just bought 3 of them, I'll let you know how they work out.
1997 Astro
front:6 sets of T3 componets
Subs: 8 level 5 18"s (building 6th order BP)
Amps: 4 really big ones (totalling just shy of 50K)
Batts:
Alt: Ohio Generator
1996 Chevy Suburban
Sub amp: A fifth really big amp
Subwoofer: 2-15" DC Level 4 XL
Batts: C&D high rate--(x4)
got the batteries in yesterday, they all rested around 12.9V, and were in nice shape. They were used, but must have been in a big UPS system do to the markings on the bottom part of the casing. Load tested the with a 400A tester, and they popped good. Put them on a 2A trickle charge for a few hours and were resting at 13.3V. gonna put them in my burban this weekend for some fun
1997 Astro
Batts:
Alt: Ohio Generator
1996 Chevy Suburban
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
