Try charging the battery then check how fast it draws with the key in ACC and again with key on but engine not running and see how fast it drops. You might have something on the motor side grounding out when you run it.
Did you also swap gauge clusters? did you leave the harness from the 95 running through the dash? The gauge cluster actually completes the circuit for the battery light on the dash. if the wiring is not right or the pinout on the cluster is not the same the alternator wont charge. My 95 c1500 had a loose connection at the plug the cluster sits into and would not charge all the time.
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
No cluster in the truck at this moment though I drove it like this for over a week with no problems. I'll put it in and see what happens and thanks for everyone's help. I'll post what I find :)
1996 Tahoe 2dr
Alpine IVA-D901 - Alpine PXA-H701 - Alpine RUX-C701
200 amp alternator - Yellow Top - Alumapro 15 farad cap
T1000-4
(2)MB Q-forms 6.5
FOR SALE AA 18" Mayhem / T2500-1bd FOR SALE
2000 Camaro SS - UNDER THE KNIFE
Twin Turbo - 6 speed - 9 sec with a/c
http://www.fquick.com/LS1king000
i dont know if the wiring changed from 95 to 96 but my alt WILL NOT charge without a cluster in, i bet thats what it is.
DC.jpgDC POWER
Put the cluster in.....everything is working!!!
Results as follows:
- At idle on the battery 13.65 V
- At 2000rpm on battery 14.25 V
- At idle under heavy load on the battery 12.5 V (Jumps around from 12.4 to 12.6)
- At 2000rpm under heavy load on the battery 13.6 V
Also I found the voltage to be the exact same reading on the alternator as the battery.
Thanks for the help :drinks:
1996 Tahoe 2dr
T1000-4
(2)MB Q-forms 6.5
  • Who's Online   1 Member, 0 Anonymous, 1173 Guests (See full list)
