Ray Posted May 10, 2007 Report Posted May 10, 2007 The bigger the box the shorter the port.. And less area means shorter port. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Eric B Posted May 10, 2007 Author Report Posted May 10, 2007 yea its actually 4.1 cu. ft. and the its tuned to 30Hz Im hoping to get my new amp and BL within the next few months, I just need to finish painting the inside which ill probably do tomorrow night and on friday my 15" P2 is coming so im gunna see how that works out, the only problem with that new box is the plexi moving it rattles and is annoying, im thinking about putting a brace down the middle with carpet on the glass side so it dont make noise, anyone else have any ideas? Quote 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
EricR Posted May 10, 2007 Report Posted May 10, 2007 if you got the cash.....look online and get some 3/4" plexi Quote i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
sean 371 Posted May 10, 2007 Report Posted May 10, 2007 Yea get some thicker plexi, it gets pretty expensive though. And if you run a brace, you'll have to screw the plexi into it for it to work properly. a window that large in 3/4" plexi will probably run you around $50. But it's necessary. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Eric B Posted May 10, 2007 Author Report Posted May 10, 2007 Yea get some thicker plexi, it gets pretty expensive though. And if you run a brace, you'll have to screw the plexi into it for it to work properly. a window that large in 3/4" plexi will probably run you around $50. But it's necessary. Ok Ill probably just put on a brace for now, maybe ill put new glass on it later aint got $50 right now :mad: Quote 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
Eric B Posted May 10, 2007 Author Report Posted May 10, 2007 But do you all think that the p2 15" should be louder than my type-r??? Quote 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
civichatch Posted May 10, 2007 Report Posted May 10, 2007 (edited) But do you all think that the p2 15" should be louder than my type-r??? I had a P1 15. And i now own a Type R. I know your Type R is only a 12" But i garuntee it will not only be louder, But sound alot cleaner. Thats just my 2 cents though. Edited May 10, 2007 by civichatch Quote System Specs: Alpine SWR-1542D 15" sub Sealed Subwoofer Box MTX mxa 6001 Class D 774watts RMS @ 2ohms MTX Bass Knob Pioneer 6.5's in doors MTX Thunderdome 6x9 in rear Stinger 1 Farad capacitor 80 amp stinger fuse BIG 3 in 4 gauge wire 4 gauge power/ground wire JVC MP3 CD Car Deck (KD-G320) 12 gauge Monster speaker wire to Sub 16 gauge Stinger speaker wire to doors Stinger Gold Plated Battery Terminals
Eric B Posted May 10, 2007 Author Report Posted May 10, 2007 I had a P1 15. And i now own a Type R. I know your Type R is only a 12" But i garuntee it will not only be louder, But sound alot cleaner. Thats just my 2 cents though. so ur sayin the type-r will b louder??? thats what i got out of it, idk i had a long day Quote 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
civichatch Posted May 10, 2007 Report Posted May 10, 2007 so ur sayin the type-r will b louder??? thats what i got out of it, idk i had a long day I personnaly think the Type R will be louder. Quote System Specs: Alpine SWR-1542D 15" sub Sealed Subwoofer Box MTX mxa 6001 Class D 774watts RMS @ 2ohms MTX Bass Knob Pioneer 6.5's in doors MTX Thunderdome 6x9 in rear Stinger 1 Farad capacitor 80 amp stinger fuse BIG 3 in 4 gauge wire 4 gauge power/ground wire JVC MP3 CD Car Deck (KD-G320) 12 gauge Monster speaker wire to Sub 16 gauge Stinger speaker wire to doors Stinger Gold Plated Battery Terminals
Forevrbumpn Posted May 10, 2007 Report Posted May 10, 2007 I would assume, the plexi window should be a good 3/4", but once you add that BL, and depending on how much power, maybe up to 1" thick plexi, anything less will eventually leave, crack, or just change the freq you hear Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
