i have the amp wired to 1ohm.. and the 4gauge is rockford wiring.. and i just bought a new 650ccw battery today.. so what do you think the best thing for me to do is? whats the difference between the block i have and the anl fuse block? thanks
Because IMO, ANL fuses fit better than AGU fuses. they are tightened down by a screw whereas most AGUs are slid/crimped in. If your voltage is fairly stable, and im assuming so since you bought the new battery, then you should just go ahead and slap on a 150A and call it a day.
its a d2400 directed amp.. it doesnt blow instantly when i turn it up loud it blows.. do they make alot bigger than the 80s? thanks
your having the same problem I was when I was using my directed
http://www.stevemeadedesigns.com/board/ind...c=55297&hl=
...maybe theres something with these amps
now I'm using a sundown saz 1500,because my directed fried, with knu konceptz wiring and a anl fuse
even though i have more power I get WAYYYY less voltage drops
...my lights only dim a little now, and thats at full tilt
Edited by Djmixmasterkid
I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass.
Open Up The Trunk
Pioneer P6000Ub H.U.
Sundown Saz-1500D
Hifonics ZXi 4410
12" Directed SX12D4 (x2)
12" 1500rms Sub x1
Front - Powerbass 4XL-65-92 Mids
Rear - Cadence 6.5" Mids
Electrical Under Construction
Check Me Out(CarAudio Vids)
Official Feedback Thread
Check Out My Music Page
Pick yourself up an anl fuse 150 and you should be straight.
I popped my first 80 fuse within like 15 minutes, switched to the 150 and have been straight ever since.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
I have two of those and they need at lease a 90 fuse per amp add the fuses on the side of your amp they are 3 30 amp fuse. You need to at lease use a 100 or 120. Try a ANL fuse. also check your Ground, cable make sure you use the same 4 gauge wire. I strongly recommend Loading it up to a 1ohm load. they love it.
Alpine D900 head unit 7" flip out t.v
Kicker 6 1/2 components (front,rear)KS 6502
MB quart 3 1/2" in front A/C vent's (center channel)
DC Audio LVL 5 18" (pair) Custom ported box
Sundown 4500 at .5
Sundown 100.4
XS 3100 up front and a pair of XS 6500 in the rear.
1 17" Eiger Vision T.V
2 7" Eiger Vision T.V in Second row.
Dynomat Top to Bottom (foam in all halo beam's)
DC Eng Alt 260SP and a 400SP dual set up.
big 3
Sitting on 24"
If your neighbor don't complain it's not Loud!
So you best go fix your shit !!!!!!!!!!!!!!
  • Who's Online   0 Members, 0 Anonymous, 2648 Guests (See full list)
