okay, so i know when using 3/4 that you divide by 1728 to give you the total cubes, but what about 1in mdf when using all external measurements and how did you come up with that number?
Edited by cstrokers
"i'd rather die like a man than live like a coward" quoted from Tupac
the same its still 1728 cu inches in a cu ft
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
but how could it be the same when you are adding an extra 1/4in. of wood, not box volume on each side of the box? if i'm correct that wouuld give you a false calculation
R.I.P!
(Nov-29-2009)
92 explorer
current build
because you calculate the inside dimentions then divide by 1728. if your doing outside measurements then your just doing it wrong.
yeah, i can do the same thing on the JL calculator using 1in, but i want to learn how to do it with an in hand calculator. i appreciate that link though. i can find other uses for that
It does not make a difference because you will use the inside dimensions and they won't change!
2001 Southern Comfort Suburban sittin on 26"s
Eclipse 6620 double din head unit (2004 dash mod)
4-AQ 3500D amps @1 ohm
8-Cadence 6.5 midbass 4- in each door.
Image Dynamics Cd 1 pro HLCD
4-runs of KnuKoncepts 1/0 power wire
4-DC AUDIO lvl 4 xl 18"s in a wall
2-MECHMAN 270 AMP alternators(2 more on the way)xs power VCM
7-Deka intimidator group 31 batts(soon to be Xs power)
2-Rockford Fosgate Prime r300.4(1 bridged on mids, 2nd on CD1 horns and rear door speakers)
1-Rockford Fosgate 360.2(operated by Palm tungsten T5)My link
man, i have always calculated all of my measurements from the outside of the enclosure when i'm first coming up with an idea. i use a program to do the final design like on JL's website when it comes down to the build though.
that sounds like it would be far more than a pain in the ass but if you wanted to make it more difficult then so be it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have alot of time on my hands and nothing better to do
  • Who's Online   0 Members, 0 Anonymous, 2058 Guests (See full list)
