it looks like hes a little below halfway.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
so you put your gain all the way up? thats not smart.
No. That amp is expen$ive (I could of bought two rockford ti4000s for the price of it), Im not going to clip it out and burn it up. Even tho I did pop it once due to not enough power... Reason why its not in my car currently because I have made voltage issues and dont need to pop more mosfets. I need to add lots of batteries for it to handle the daily driving abuse..
Correct. Its a little below half, since Id assume that half way up would be about 3 volts, and my deck is 4volt, so a little below half should ruffly be 4 volts.
Hence the reason I dont think them gain calculators are too accurate, because if it would be, 54.8 volts should mean setting the gain around 4 volts, and not a fraction of a turn up from the lowest gain setting..
I just found it interesting that groundpounder had the same issue with them calculators that I had.
Edited by audiofanaticz
  • Who's Online   0 Members, 0 Anonymous, 1914 Guests (See full list)
