Ronin Posted November 28, 2009 Report Share Posted November 28, 2009 I just bought a kicker L7 off ebay,and the coils read fine,but when I push on the cone it's scratches and gets stuck(doesn't move freely) Link to comment Share on other sites More sharing options...
treossi Posted November 28, 2009 Report Share Posted November 28, 2009 yeah that things is probably locked up... put some power to it and see what happens Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details Link to comment Share on other sites More sharing options...
Ronin Posted November 28, 2009 Author Report Share Posted November 28, 2009 yeah that things is probably locked up... put some power to it and see what happens Will power unlock it? Or eff it up more? Link to comment Share on other sites More sharing options...
raytard Posted November 28, 2009 Report Share Posted November 28, 2009 sounds blown yay ebay make a stink about it and try to get them to refund you Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
CodyB Posted November 28, 2009 Report Share Posted November 28, 2009 Um, is it L7's or Solo's that are reconeable? 88-98 GM Full Size Forum www.GMT400.com i put fuses on power wires, and condoms on fuses, to keep the fuses safe! Link to comment Share on other sites More sharing options...
Mendozauly Posted November 28, 2009 Report Share Posted November 28, 2009 L7 and solo are the same thing. I own a pair of L7 Kicker Solo Baric 15" . Hey if you find some one to re-cone it hit me up i have two 12" L7 2005 model the crome or Silver color ones. I also need to be fix. Alpine D900 head unit 7" flip out t.v Kicker 6 1/2 components (front,rear)KS 6502 MB quart 3 1/2" in front A/C vent's (center channel) DC Audio LVL 5 18" (pair) Custom ported box Sundown 4500 at .5 Sundown 100.4 XS 3100 up front and a pair of XS 6500 in the rear. 1 17" Eiger Vision T.V 2 7" Eiger Vision T.V in Second row. Dynomat Top to Bottom (foam in all halo beam's) DC Eng Alt 260SP and a 400SP dual set up. big 3 Sitting on 24" If your neighbor don't complain it's not Loud! So you best go fix your shit !!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
knowledge Posted November 28, 2009 Report Share Posted November 28, 2009 sounds like you got jerked! REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need. Link to comment Share on other sites More sharing options...
ISO Posted November 28, 2009 Report Share Posted November 28, 2009 Are you putting even presure on the cone when you push it in? 1st is it new or used? If used you need to file a complaint quickly. Instead of pushing on the cone I would preffer you hook it up to an amp in a free air setup and test it first. Your house stereo might even work for this little test as you shouldn't need much power to do this. I preffer you use a test tone, somewhere in the 30 hertz range and even a 50 watt amp should make that woofer go to full excursion with a test tone as long as its being free aired. If no test tone use rap and don't confuse mechanicle noise that the woofer will make naturally with coil issues. You should hear scraching sounds if its the coil. Try free airing it with test tones first before you start to worry to much. There are many places to download test tones for free man. Quite honestly the suspension on those woofers is so tight you shouldn't beable to push in and out on the cone enough to find out and if its new and you are doing this then you might mess up your L7 by trying to force it with you fingers or put a finger through the cone or crack it. I have owened alot of L7s man and theres not much I don't know about them so try out what I told you first before you start to worry too much. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
BeAlLsTaR13 Posted November 28, 2009 Report Share Posted November 28, 2009 like i said on ca.com, put power to it, or run it parallel to a wall socket OR pop test it, just connect a 9 volt battery in parallel to each coil, parallel will make the sub go out, series will make it go in, harmless Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
ISO Posted November 28, 2009 Report Share Posted November 28, 2009 like i said on ca.com, put power to it, or run it parallel to a wall socketOR pop test it, just connect a 9 volt battery in parallel to each coil, parallel will make the sub go out, series will make it go in, harmless Not trying to step on your feet man but don't you think the wall socket trick might be a little too much power to test out a subwoofer thats in this catagory. I mean an L7 15 will only hold up for about 3 minutes before it blows up. The wall socket should be a very, very last resort and really IMO should never be a thought in your mind unless you are dealling with some of the major hard core suboowfers out there. A 9 volt battery won't be enough either. I recomend useing a drill battery 12.5, 14.4, or a 18 volt. The 9 volt just doesn't have what it takes to make an L7 go to and from full excursion. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
