That is ok right? Like nothing bad can come from that?
The thing is my amp keeps sliding around and the wires are slowly coming loose from the connections.
I wanted to clean up my install a little too. It's my first one but I don't want to use that as an excuse.
RE SE 12" subs (2) in prefab dual ported box (custom box coming soon)
Hifonics bxi610 mono 600 watt amp
Stock HU
Mach RCU
Apline 5 x 7 S Type Speakers (2) (1 blown)
Stock rear speakers (2)
Pyramid Tweeters (2)
A thousand people will tell you this, but here it is. Screwing an amp directly to the box with no sort of bushing/dampener between it and the box will definitely shorten the lifespan of the amp. The vibrations caused by the subs can crack apart the internals of the amp over time. Like for instance it can deteriorate solder points and cause resistors etc. to fall off the board. I would recommend fastening the amp to the floor or another surface.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
if you have no room to do otherwise you kinda have to
ive got all 3 of my amps screwed to my box becasue my box is taking up my whole trunk if i had no room on my box for amps... i would have no where to put them other in laying accross my back seat
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
That's what I thought.
It doesn't really have to go on the box. I have the space where it's at now. I just wanted it to look neater.
I can probably get some rubber bushings though.
Stock HU
Mach RCU
ive witnessed a toroid falling off shorting/sparking
seen mosfet legs break from heat+vibration
add another piece of wood to mount it on, that helps alot
so u have 1.5" thick or more, plus rubber washers and a well braced box... if u have to
Edited by Decaf
one reason not to mount it is if someone goes to steal your system its a complete package...I know from experience
My cheap-o amp lasted over a year mounted to my box
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
theres like 35 of these threads, search nex time
its fine as a last resort, but if you can avoid it, please do, because nothing good can come from the extra vibrations.
Team DC
I'm pretty sure Steve has his amps mounted at the base of the box.
I'm pretty confident that he knows what he's doing too.
his arent attached to the box lol theres 2x4s around the amps and the box does not touch em
