those are nice
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Beautiful, could you explain the purpose of the aluminum ring and the machining in the top/bottom plates?
The aluminum ring purpose is as follows :
http://www.stevemeadedesigns.com/board/ind...showtopic=60550
Read all the way through (my posts).
The top / bottom plate holes / machining are indeed for cooling the coil. The top plate vents are not extremely active until the 18" model as it uses a 6-spoke non-vented basket. I won't have to use the spacer nuts any more. They give the coil a little bit of fresh air on all sizes, though :)
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
I think one of these is going to replace my Z15.
Any idea on the amount of air space the 15 will require? Same as the V.1 or is it too early to tell?
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
:blink:
VehicleCurrentlyOwned:2000Malibu
\/MySystem\/
Ken-Wood HeadUnit
Cars interior panels Custom blue Done by ME
Pheonix Power block running both amps
Stinger pro series four gauge wire flex material
RimsBrand:Polo
Interior lighting Blue neon bars under and around dash
Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED)
http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg
http://www.dcsoundlab.com/images/header.jpg
Cool cool. I have some nasty ideas now that I know itll fit in my trunk.
Alpine CDA-9886
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
Here are some T/S from the 15" D1 that I built for myself with 3 Hard spiders (stock stiffness):
RE: 2.09 ohms (D1 series)
Fs: 32.16 Hz
Qes: 0.48
Qms: 12.04
Qts: 0.46
Le: 2.86 mH
Vas: 47.05 L
BL: 20.07 NA
Cms: 53.44 uM/N
Mms: 457 g
The above with a very short break-in period... Fs will drop a few more Hz when fully broken in. My FEA simulations show 27mm of linear excursion by 70% BL method + it has dual shorting rings to lower inductance related distortion. The at-rest Le is actually roughly equal to the v.1 Nightshade which had a much shorter coil.
- Jacob Fuller
Fs: 32.16 Hz
Qes: 0.48
Qms: 12.04
Qts: 0.46
Le: 2.86 mH
Vas: 47.05 L
BL: 20.07 NA
Cms: 53.44 uM/N
Mms: 457 g
I'm liking that low Fs
97 Maxima SE
Bunch of shit going in, check out the build
  • Who's Online   0 Members, 0 Anonymous, 2400 Guests (See full list)
