if you dont know what strappable means then forget it. I would just get a bigger amp.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
could explain it lmao ? isnt like i wont under stand if you give an explination
strapping amps is hooking the amps to eachother to only have to tune one and the speaker is hooked up to one amp and the other amp is the slave amp... if you dno how to do it and dno if your amps can do it then most likely they can't... do your amps have an output on them?
Johns.jpgSuburban Coming Soon
2k will be fine.. jus build a larger box, to make it more efficient.. my teammate got 1 18" BTL and his box is like 10cubes after all displacement and pulled a 149.9 at 42hz off 2000 clamped watts..
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
More efficient enclosure and with 2k you will be just fine.
Pioneer AVIC-N2
what kind of vehicle was your freinds btl in? Suv?
  • Who's Online   0 Members, 0 Anonymous, 2178 Guests (See full list)
