SSD or Q 18"
16 members have voted
  1. 1. Which 2 subwoofers??
    • 2 Fi Q 18" with free Bp option
      7
    • 2 Fi SSD 18" with all the options
      9
Ok so since they are the same price which ones would you personally choose? But what does the flatwound coil do? does it increase conductivity?
Can the Q's get pretty loud and low?
And las WTF do all these letters meen??
Fs: 24.7 Hz | 24.3 Hz
Qms: 4.88 | 4.96
Qes: .75 | .69
Qts: .65 | .61
Mms: 296g | 308g
Cms: 0.14mm/N | 0.14mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 285 l | 285 l
Spl: 89.4dB 1W/1m | 89.6dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Sub OD: 18.500”
Cut ID: 16.750”
12 RE audio X series 12's
4 gauge wiring to back batt (soon to be 0 gauge)
0 gauge from batt to amp
kinetik 1800 in back
clarion cx-200 HU
SPL 3000 wired at 2 ohms
8 Re 6.5 full range speakers
Re Xt 800.4 4 channel amplifier
Autopager car alarm
q's ftw
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
What amp(s) are u running and what do u drive??
Pioneer AVIC-N2
ssd is louder then a Q
Q is better sounding by a very small margin
ssd with copper coil is cheaper then a Q and worth every penny
since everyone ignored your question read up
http://www.bcae1.com/spboxad2.htm
how much louder would they be on the same amp? And how much power can the Ssd's take with the options?
clarion cx-200 HU
Autopager car alarm
7db.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
Ive got roughly 1k on each of mine...no sweat at all. kentb is putting a 3250 on 2 10's and doing a 150.
Systemless.
Not set on the amp yet im just planning right now but probably AQ2200 or something around the same power and a 1998 dodge van FTL. But i'd rather just put all my money into what i have than buy a brand new car.
clarion cx-200 HU
Autopager car alarm
5.667894db to be exact....
Might actually help if u listed what size enclosures you'll be using, the amp(s) you'll be running, and we can't tell you how loud each one will be, our guess will be as good as yours.
Pioneer AVIC-N2
