Well im gettin ready to get new amps and equipment in so im gonna dampen alot of the car. I Was wondering what yall would recommend when it comes to , Damplifier, Damplifier Lite, And Damlifier Pro. Which Has Better Results And Still Gives It The Loud Bass From A Block Away
SS Damp Pro is the best deadener I've ever used.
Pioneer AVIC-N2
sound deadening has nothing to do with the bass being heard a block away
it is used to stop the rattles or more technically dampen the panels it is attached to...
I would only buy dynamat, hushmat, or the second skin product... though I really like the hushmat material, anthony sent me some second skin to use... which is not as pliable as the hushmat for organic shapes and curves, but worked great on the inetrior door skins
the rest of the stuff out there is just junk... and the people using the tar paper crap, well... it is just that stinky crap that will eventually come up
SMD SuperSeller VerifiedJbondoXJames Shields
sweet. :01nocomment8so:
Glad to see so many Second Skin Damplifier Pro fans in here.
Dynamat Extreme and Hushmat are both great product.
Hushmat silver is better than husmat black, whic has a mylar facing rather than a foil one.
Our Damplifier compares to both Dynamat and Hushmat very well
Damplifier Pro is in a class all on its own.
Then there are the SPL Tiles.. WHOA!!
My thought is that you should always put whatever money you have for sound deadening, and spend it on the best available product for the best possible price. then spread that evenly over the entire surface area you are trying to cover.
I'd rather use $100 of an awesome product than $100 of crap, even if I got 10 times more crap..
Hope that helps!
ANT
  • Who's Online   0 Members, 0 Anonymous, 1304 Guests (See full list)
