Another Voltage Problem Thread
Your charging voltage seems low for having a high output alt. Correct me if Im wrong but shouldnt most cars charge around 14.4 or 14.5.
Did you go to a larger alt pulley when you changed alts?
If the voltage is computer regulated by the vehicle then it won't let it charge higher without a mla or a vcm or something similar.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
maybe its just me but i dont think youre supposed to ground your alternator, just from the battery and from the engine block.
please explain why you wouldnt ground your alt. Its an electrical component. all electrical components should grounded.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
For best performance a 1/0 ground cable should be run from the housing of the alternator directly to the negative terminal of the battery
thank you mr alternator builder guy ;)
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Alright here we go after checking voltage with the DMM. At start up I am getting 14.1 to 14.2 volts. once heated up it rest at about 13.89. I used the same song and just replayed to get results. Throw it up by lil jon
The first results are with high beams and ac all the way up.
Battery:13.8 when ac compressor turns on it drops to 13.4 then quickly gets back to 13.8
Alt: Same as above
Amp: Same also but seemed to drop to 13.3 some times.
Results with volume a little under 3/4 the way.
Battery: rest at 13.89 drops to 13.1 to 13.2
Alt: same as above
Amp:13.89 drops to 13.0 to 13.2
Results with volume at a little above 3/4 volume.
Battery:13.89 drops to 12.5 to 12.7
Alt: Same as above
Amp: same also!!
Full tilt=instant protection mode on the amp and voltage near 12.0
Edited by yota_oddball
04 Armada. Lifted 35" Toyo MTs.
Sundown 1200saz
Fi Bl Fully Loaded
Alt: Same as above
Alt: same as above
Alt: Same as above
Amp: same also!!
possibly a bad cell in the battery?
also check your connections for corrosion. power and ground.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i dont know if someone asked this before but why do you turn your headunit volume all the way up (as i read "full tilt"). do you know what volume your headunit clips at?
I never do. I only did it for the test. I got dimming with half volume and on some songs lower.
Sundown 1200saz
Fi Bl Fully Loaded
  • Who's Online   0 Members, 0 Anonymous, 1825 Guests (See full list)
