Browne Posted May 20, 2007 Report Posted May 20, 2007 I thought capacitors are supose to help small systems ????? i have a 6farad cap and its not helpin me one bit...my battery is new and that sucker is already hitting 10volts System specs Beyma Pro 8MI (2) Rockford P550.2 Rockford T20001BD MTX 9512 (2) HO Alt 200amp BIG 3 Pioneer AVH-P4900DVD Clarion EQS746 AudioControl EPIC160 Kinetik HC2400
roscoe1129 Posted May 20, 2007 Report Posted May 20, 2007 I dont like caps to begin with but the pyle brand is not that solid to begin with. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
Browne Posted May 20, 2007 Author Report Posted May 20, 2007 hmmmm i c....whats a good brand? System specs Beyma Pro 8MI (2) Rockford P550.2 Rockford T20001BD MTX 9512 (2) HO Alt 200amp BIG 3 Pioneer AVH-P4900DVD Clarion EQS746 AudioControl EPIC160 Kinetik HC2400
Cloak559 Posted May 20, 2007 Report Posted May 20, 2007 Even good capacitors are better used as paperweights. For your dimming lights I would suggest you upgrade your Big 3. The Big 3 is upgrading the thee main power wires under your hood to help the flow of electricitiy which in turn aids in the prevention of voltage drops... The Three wires are: -Battery Negative to Chassis(Ground) -Battery Positive to Alternator -Engine Block To Chassis(Ground) These three can be upgraded fairly easy and will give a big helping hand to your charging system. I would use nothing smaller than 4awg wire...1/0 would be preferable... Do this and your voltage drops should subside... 2001 Blazer Pioneer 5900IB - (2) DC Level 3 10"s - Sundown 1500D
Browne Posted May 20, 2007 Author Report Posted May 20, 2007 aight kool....thanks System specs Beyma Pro 8MI (2) Rockford P550.2 Rockford T20001BD MTX 9512 (2) HO Alt 200amp BIG 3 Pioneer AVH-P4900DVD Clarion EQS746 AudioControl EPIC160 Kinetik HC2400
