BeatBox Posted December 17, 2009 Report Share Posted December 17, 2009 I checked around in the subwoofer/enclosure topics and didnt see anything. Im making my speaker box and wanna kno whats the best way to get the speaker wire into the speakers? any help would be appreciated. THANKS Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted December 17, 2009 Report Share Posted December 17, 2009 Easiest would be drill a small hole run your wires through then silicone the gaps. Next, and probably the best and most cost effective, is depending on how many coils you have use bolts and nuts. So if you have 2 dual 2 ohms coils you would want 4 bolts then on the inside of the box you connect a coil to each bolt, on the outside then you can connect the bolts via wire and ringterminals to achieve whichever ohm load you are seeking. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
BeatBox Posted December 17, 2009 Author Report Share Posted December 17, 2009 I C im prob gonna run with the nuts and bolts. The thickness/lenght dont change anything right? as far as ohm load. Link to comment Share on other sites More sharing options...
bigmescan Posted December 18, 2009 Report Share Posted December 18, 2009 I C im prob gonna run with the nuts and bolts. The thickness/lenght dont change anything right? as far as ohm load. yeah run bolts and nut and use lockwashers on the inside so when you go tighten the outside wires on box they wont spin and i put silicone in the hole as well and it should hold it. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
Gotloud555 Posted December 19, 2009 Report Share Posted December 19, 2009 Easiest would be drill a small hole run your wires through then silicone the gaps. I do this all the time and never had issuses. The nuts are bolts look more clean but just extra money to spend. Link to comment Share on other sites More sharing options...
Nirvalica Posted December 19, 2009 Report Share Posted December 19, 2009 I just ran the wire out the port haha Before I've used terminal cups, but I didn't have one for this box when I built it. My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted December 19, 2009 Report Share Posted December 19, 2009 Just wire it straight through a small hole in the back or side.. Drill a hole just large enough for the wire to fit through and silicone around the wire once it's run through. Make sure to have it be the appropriate length, plus a little extra. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
knowledge Posted December 19, 2009 Report Share Posted December 19, 2009 any particular bolts guys? or what is the best to use? REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need. Link to comment Share on other sites More sharing options...
CLNFREAK Posted December 19, 2009 Report Share Posted December 19, 2009 I used bolts lock washers and lugs so I didnt need rings in the wires from the amp to the box. Link to comment Share on other sites More sharing options...
