coil burning??
LoudBimmer
come on nfs... u know better
likely u introduced clipping
either from having bass features turned on on ur deck
too high of volume #
bass boost on amp is being used, which it shouldnt
gain is set too high
are you using the bass knob as well?
bass boost was on, bass on deck is at 0, loud is at 2
gain was half way up and i used bass knob.
Your probably clipping the shit out of it bud. Turn all bass boosts and "loud" features off and set your gains with a dmm or o-scope and you should be good to go.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
bass boost should be off, bass on deck should be 0
loud should be at 0... dont use the bass knob right away until ur used to knowing when to turn it down
bass knobs are great but if u arent next to the speaker u cant always here when its distorting... so get used to ur sub without it
remember the bass knob is used to turn the gain DOWN from its highest point u set it at, and bring it back up to that point once u want it loud again
they are not to be used to add bass to a song
the sub is rated for 600rms so i dont think youll burn it out. knowing DC you could probably run 1200 to that thing all day.
doubtful. Its the same sub as an RE Se, and i wouldnt run more than 750 on those daily...But i know what you're getting at.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
Rusty said i could easily run 1200wrms.
cool, put it on 1200 then lol...
although i will say for you clipping it at 600 i would hate to see what you do to it at 1 ohm...
Eclipse cd7000
  • Who's Online   1 Member, 0 Anonymous, 1556 Guests (See full list)
