Bypassing a Pioneer h/u help
I found this on a review of the h/u
For setting this up to view DVD's while driving (bypass safety lock-out), you'll need to get a standard 5-wire automotive relay and wire it up per these instructions:
1. connect "30" to the parking brake wire from the headunit
2. connect both "86" and "87" to ground
3. connect "85" to the remote turn-on wire from the headunit
What this does is send a pulse to the headunit to trick it into thinking you've turned on the parking brake. If you simply connect the parking brake wire to ground only, it will not work.
does this look like it would work?
For it to play video while driving right? just ground the "eBrake" wire to the main ground wire of the head unit and it should work i have a pioneer 6600
Edit: it worked for me hopefully it does for you too!
. The wire for you need to hook up is on the back of the h/u. Use the relay and youll be good. your suposta hook it to the switch on the e brake in the car that lights the dash light up.
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
thank god for alpine and their bypassing modules.
but grounding it to the e-brake should work.
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
no need to buy a module.
the relay works perfect.
I love how some of you F**ks just post up shit you have no idea about.
Grounding the ebrake wire will not work on new pioneer models.
shit, hasnt worked for at least 5 years.
The switch to ground will also work, but sucks that you have to do it everytime you want to watch movies.
the relay does it automatic everytime.
explain the relays please
  • Who's Online   0 Members, 0 Anonymous, 1025 Guests (See full list)
