this is gunna be a long one guys. sorry
ok so i have an '01 chevy blazer and i've been having some problems with it. it was running really rough and smelling like fuel so i threw my neighbers snap on scanner on it. its the red one that looks kinda like a brick. so anyway, it came up running rich on bank 1 and 2, and random multiple misfire. so i tried to take care of the misfire problem by changing the spark plugs, then the wires, then the distibuter cap (they were all the original ac delco parts with 104000 miles on um). none of that worked. helped a little but not much. so at this point i was kinda stumped. so i brought it over to goodyear to have them check it out. after about an hour and a half they call me back and say its a bad fuel injector, gunna cost around 500 between diognostic time, parts and labor. so i let him go ahead and do it. after hes done he calls me back and says the injector helped but the fuel pressure regulator is bad also and its gunna be another 200. so i was kinda pissed but i let him do it anyway. sooo $700 later the guy calls me back and goes ok the injector and the fuel pressure reg. took care of the running rich problem, but its still misfiring at the number 4 cylander. it could be that since it was running so rich there is exces fuel in the cylender that just needs to be burnt off, or if its not better in a few weeks possibly a cam. so what do you guys think? is this guy telling me the truth or he completely full of it? it is running better and starting quicker than it used to. but i still have the check engine light from the misfire and its still running pretty rough at idle.
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
go to ya buddy scanner and see what code it throw cuz its multiple things that can cause a misfire and it may be just 1 thing that tied along with those systems that could make it misfire and burn rich.
I know a lil about everything so dont call me Mr. Know it All.
take it to a speed shop.
your getting rapped at the "goodyear".
you can hook an o-scope to each injector and see if it's misfiring
excess fuel will"burn off" in seconds, not weeks.
a cam wouldnt be "random"
compression test good across the board?
leakdown?
leakdown?
I didn't know You were a mechanic Ray :P
But yes, all this information is correct^^^^
816-591-6592
www.kcrimshop.com
did u change the distribitor pin also?
but missfireing could halfto do with electrical and cam too, not enough air to fuel mixture n u get no boom in that cylinder, could be the timeing also but i dnt see how its missfireing on just one cylinder off timeing
might be a bad valve if its a missfire cause without it lettin enough fule into the chamber u get no explosion and no vroom
heres a video of how one works n what all it takes to make one run, maby u can check all the cheap stuff first befor u go into buyin a cam n what knot
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
im not a mechanic but my uncle is n i can ask him if u want me to cause replaceing a cam aint cheap but replaceing a valve aint either
hope u get it fixed, did u try checkin the fuel lines to make sure ur gettin fuel throughout the whole engine?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
i always take things to the local mechs, not the major ones like monroe, goodyear, firestone etc... they just rip you off hard
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
ok my frieds got an oscope i might give him a call. how do i scan it wit hthe oscope? also the compression on the number 4 cyl is a liitle low . not sure exactly what it was but not as much asw it should be. thanks guys
New Project
[top secret]
Sounds legit, but did he just replace 1 injector? If so, thats HIGH...
dont know how many he replaed but remember that on those engines the injector rail is inside of the intake manifold so ther is a lot o R&R. prob about 3-4hrs at 80-90- per hour soooo
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
yea he only did one and i double checked that because i though it sounded high too. but after some googel searching i found out how muich of a pain in the ass it is to get to
New Project
[top secret]
well a bad or bent valve would not be random.
no fucking way its timing.
how low was the compression on cyl 4?
to use the o-scope just set it to a/c volts and probe both injector wires. it will look like a bunch of spikes.... if it stumbles you will notice the spike missing.
and sam..
"I didn't know You were a mechanic Ray blum.gif lol"
I know my fair share.
It's kinda my job to know.
I work on cars all day, stereo or not , i think a tech should know vehicles inside and out.
Im MECP advanced cert. and ase cert.
Lets see, alot of people dont know Im a helicopter depot level turbine repairer.
