trunk battery question ?
so I am going to put two C&D batterys (these : www.cdstandbypower.com )in the impala, I was going to put a 12V Continuous Duty 200 amp Solenoid between the car battery/alt and the rear batterys. the rear batterys will be run in paralle for 12volts. the altanator is 150 amp. or
should I put solenoid on each battery ?
can I use a smaller solenoid or is bigger (I am no where near 200a) ok ?
no solenoids
DC.jpgDC POWER
X2
x3 there is no need for them. only fuses. Even a constant duty silenoid would get too hot. A silenoid is a large relay, if u'd like to think of it that way, theres no turning the power on and off= no need for silenoid. Hope that helps some....
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
is this still true if the front battery is a regular "liquid" battery and the rear ones are agm.
isolator will cause to much voltage drop. I think
Fuses or isolators have resistance so you do get voltage drop. I did add fuses don't bother with isolators because that good for turning off your vehicle while you play your system with battery on only.. NOt not good for the system..
  • Who's Online   0 Members, 0 Anonymous, 525 Guests (See full list)
