Justin's Yukon Build! Update! 9/12 NEW BOX /SoundStream 4 18's XXX15k
I know that I was gonna have build it a different way but keep same specs and stuf
You have less than half the cargo area. Get yourself a measuring tape and go to town. He had 4 18's, you aren't fitting that unless you wall it to the B pillar. Regular box 8-10cu, C wall 13-15cu, B wall 39cu unless you move the fusebox then more like 50cu.
Also he hasn't even had the jeep for like 2 years or more now.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
That box was huge an only played low notes which is kool but it won't work in your ride
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If you change things it changes the specs so they are not the same.build your own spec your own and then model the design style after his. That's the easy way
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Some people just don't listen n8
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
i think he means get the cubic feet and port specs of justins. then build with his dimensions to match justins cubic feet and what not.
20cubic feet is 20cubic.....
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
Believe it or not, this is wrong.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Yes what Bass14 said lol he knows what I mean
He's poking fun at you... Go make a thread for what it is you're looking to do after you take some measurements and people will help you out. This isn't how you do it because it doesn't work. The MOST you can fit is 2 18's in 9-10cu unless you wall it. That's it... That leaves zero room for batts and amps so you either have to build a rack under the box where you can fit 2 batts in the cubby with amps on either side or put the batts under the truck, lose your spare, and loose seat lock because your amp(s) are on them.
I know this because I have a Trailblazer... The sizes I mentioned above in my previous post are how much room you have to work with unless you do a box from the tailgate to the front seats, for that I have no idea, but you still won't have anywhere to put your amps.
Pioneer X8500
Second Skin
2 270a Mechman Alts
hdorre out of curiosity explain to me how 20cubic feet is not 20cubic feet?
Wiring-Memphis
