So im building my first glass enclosure and im jw what kind of resin, weight of the mat, brands to use, things to stay away from...etc.... people have used for their setup. i just need to know what the best would be to use for my system so i t doesnt fall apart on me lol
Dc level 4 18
ported box 6 cubes tuned to 34 htz
1.5 cubic ft. port area
Big 3 done on 0 gauge
knukonceptz wiring throughout
kinetik in back
AQ 2200d
i use the bondo resin you can buy at any local parts store, i use fleece material as well from walmart or whatever
I aggree with using bondo resin and cheep fleese. Works well for me
-Car: 2006 Ford expedition King Ranch
-Subs: 2 FI BTLs 18 fully loaded
-amps: 2 sundown SAZ 3000D
-Alternator: DC Power 260 amps
-Batterys: 2 optima yellowtops
-A whole shit load of 0 guage knu hyper flex and raptor cable
-Rockford Fosegate 3sixty
the bondo resin is ok to use, tho b-440 is nicer imo. but i will NEVER use bondo mat again. compare it to the mat from US composites and it's just plain crap. it's 'fuzzy' as all get out, and the layers dont like to separate.
http://www.shopmaninc.com/mat.html
this stuff is much much nicer. i have like a lifetime supply in my garage lol
Get white fleece so you can see how thick you put the resin on.The darker the resin the better,don't be shy.Alot of people use paint brush's to apply I don't. I like to use my hand so I can play with it more, and rub it in better.Just double up your gloves.and good luck.
wunna play halo?
okay thanks, what about the oz. mat to use. Should i go with a lighter weight and do more layers or get something more hefty and do a few less layers
Dc level 4 18
kinetik in back
AQ 2200d
Elmers is a good resin to use if your a beginner it will give you more work time and be more forgiving if you heavy handed with the hardener.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Don't use fleece. Use Ponte. No more suggestions of fleece from here on out.
Bondo brand resin and mat is supposedly pretty poor quality stuff, but for the one time project, and for a beginner, you wont notice a difference. You might have a little extra work for yourself in the end, (sanding wise) but that's exactly what a beginner needs to be honest.
If you plan on doing alot of glass work, put your money into quality supplies. If you're doing a small box, or some kickpanels and that's probably the end of your fiberglass experience, I wouldn't waste my money.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
I prefer to use lighter mat or cloth and do more layers...it lays down better, less bubbles, of course you lose time when you have to add extra layers but I don't personally mind.
My YouTube Videos
  • Who's Online   0 Members, 0 Anonymous, 1514 Guests (See full list)
