Team_DC-Derrick Posted January 13, 2010 Report Posted January 13, 2010 i linked you what it needed to be... The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Decaf Posted January 13, 2010 Report Posted January 13, 2010 its very simple math bro take the rms wattage u want to set it at multiply that # by the resistance ur sub will be then square root that number 3000w(rms)*2(ohms)=6000 sqrt6000=77.46v the exact same thing armyguy linked u to, lol
tumminellon Posted January 13, 2010 Report Posted January 13, 2010 oh shit sorry army-guy the pic didn't come up at first TermLab 148.9 @ 39hz BURP 148.8 on music
fritosaregood Posted January 13, 2010 Report Posted January 13, 2010 There are tons of topics on here already on how to set your gain with a DMM. Sadly I never saved any of them. Here is a simple way.Set all the gains on the H/U on zero, or off. Turn the gain on the amp all the way down. Unhook the sub(s) from the amp, and plug the DMM into the amp. Play a 40-50hz tone, you decide which one, all in that range will work (I personally used a 50hz). Now the formula with an example. Let's say you want 500 RMS. You will find the square root of 500 which is 22.36. So if you are running the amp at 1 ohm, you will want the DMM to read out 22.36. If you are running at 2 ohm, you will want the amp to read out 44.72 (which is 22.36 x 2). So on and so on. Wrong!! If your are running 500 watts at two ohms you multiply the 500x2 then take the square root. dont multiply after you take the square root 500 at 1 ohm = sqrt(500 *1) = 22.36 volts 500 at 2 ohm = sqrt(500 *2) = 31.62 volts 500 at 4 ohm = sqrt(500 *4) = 44.72 volts also dont put every settin on the HU at zero set your gains. then boost every setting. if you leave the sub settings off and have the eq for the low frequecies down when setting the gains, leave them off. and some ppl say to set you deck at 3/4 volume, but when you have every setting at 0 you can usually turn it all the way up without clipping. I have a premier deck. and an oscope I can have the volume at 61/62 with no clip, im almost positive there is still no clip at 62 but say i turned the eq all up, the bass to +6, loudness on, then it could probably clip at 30/62 seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
kirill007 Posted January 13, 2010 Report Posted January 13, 2010 Yes, but not everybody has a Pioneer HU, i saw a thread about when a Alpine HU starts clipping and it was at about 25 out of 31 or 32. Thinking is the root of all problems... You ALWAYS get what you pay for.
fritosaregood Posted January 13, 2010 Report Posted January 13, 2010 Yes, but not everybody has a Pioneer HU, i saw a thread about when a Alpine HU starts clipping and it was at about 25 out of 31 or 32. my point is not if everything is set to 0 My is rated 4 volt outputs but when its all it zero, i think mine was down to 2.5 volts. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
tumminellon Posted January 19, 2010 Report Posted January 19, 2010 would the table of voltages above that ARmyguy posted work with a 4 channel when setting the gains? TermLab 148.9 @ 39hz BURP 148.8 on music
basshead4life Posted January 19, 2010 Report Posted January 19, 2010 how high are you supposed to turn a headunit to get the voltage out of it? because my stockers start distorting at around 40-45 with everything at 0. but my preout voltage is only 0.14 at best but i cranked it up to 55 with the stockers screaming at me i still only got 0.55. and i read it supposed to be 2.2. its a pioneer deh 2000mp Edit i turned the bass to +4 when it was at 55 Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
Decaf Posted January 19, 2010 Report Posted January 19, 2010 how high are you supposed to turn a headunit to get the voltage out of it? because my stockers start distorting at around 40-45 with everything at 0. but my preout voltage is only 0.14 at best but i cranked it up to 55 with the stockers screaming at me i still only got 0.55. and i read it supposed to be 2.2. its a pioneer deh 2000mpEdit i turned the bass to +4 when it was at 55 u have 2v preouts, so maybe try going to +6, does this headunit have a hpf for the interiors so bass isnt played thru them?
tumminellon Posted January 19, 2010 Report Posted January 19, 2010 would the table of voltages above that ARmyguy posted work with a 4 channel when setting the gains? so would it work??? TermLab 148.9 @ 39hz BURP 148.8 on music
