Personal opinion
Drek75633
Do you know what its gonna take to hold up 32kw in a daily driver?? I dont see in happening. If you do, then good job
my car peaks at 45hz no matter what freq my box is tuned at..
a wall would shrink the cabin space which will change the resonant frequency up
liquid nails has always sucked for me, titebond ftw
proper bracing locations can help alot too
Exactly. The smaller the cab. The higher the resonant frequency. Proper bracing throughout the box will also raise db's. And I've never heard of titebond. I'm goin to have to check into that. At the comp today my bracing for the port started breaking. I had used liquid nail to support them. Oh well. This box I have now is just a pos... I didn't get the numbers I wanted because of the box.
2004 Mustang
3 18s
6 crossfire bmf 1700s strapped @ .5
161.2 db Daily driver
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
http://www.youtube.com/Drek75633
No it won't. Internal turbulence, dodgy loading of the cone = less dB. If your SPL box is flexing enough that it needs bracing then you built it wrong.
10.x volts fo' life!
Remind me how you're going to tune at 35hz and peak at 44hz? I've never seen a car peak 9hz off the tuning frequency...
Not to be that guy but my car peaked exactly 9 hz off of tuning freq. Tuned to 33 hz and peaked at 42 hz.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
@_____@
I would have to assume your box had a very small/no peak (bass shelf response) and your car had a peak at 42hz...
To rephrase... it will never happen with a competition-orientated box.
Ya I know. :)
That box sucked. It was too small. And it didnt do shit on the TL. Hahahaha.
Alpine CDA-9886
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
You should build a test box for one sub. Figure out how much space you have and make your test box half of that. Use a round port, start with a low tuning and go up from there until you reach a reasonable compromise on tuning and SPL. One sheet of wood seems like a good investment if you are going to be walling your car off.
