I charge a single Yellow Top at 14.9v. It rests at 13v and works fine.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
larger battery banks require a higher charge to get over the internal resistance of each battery. 15.x volts is ok if you have several batteries to charge but I wouldn't put it on just one. Kinetiks rep said it is fine to charge my battery bank at up to 15.3v but not to exceed 15.5ish or it will start to cook the batteries.
Wrong....
Also depends on the battery my batteries say on them to charge at 14.7v.
But I agree with what your trying to say, some people are getting a little crazy about high voltages. Is 15v the new 14v?
Edited by Bigg Boy
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
Over charging the battery can be unhealth for it. I know i charge my battery but not for long time. A weak or dead battery can kill an alternator....
A weak or bad alternator is a weak or bad alternator. If you have a weak or bad battery you'll likely find out about it before a good alt is damaged.
edit - and you cant overcharge batteries unless you are using too high of voltage.
Edited by STEvil
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 14230 Guests (See full list)
