0 gauge for the big three with stock 80A alt??
Yall need to lay off the drugs! 4 gauge is MORE than plenty for a couple short runs of the "big 3".
Your dimming is NOT because your wire is too small, it's because your electrical system needs help. If you're looking to spend money buy a battery.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
op, YGPM
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Your electrical is only as good as its weakest link, which I feel that on a vehicle with stock alt / regular battery is the stock wiring.
Easiest thing to do is go ahead and do big 3 in 1/0.. You can keep 4 guage for the run for now but if you do upgrade like you talked about you wont have to redo the big 3, youll just have to replace that run with 1/0.
And with systems, you will (most likely) always want more in the future so its easier to overcompensate now than it is to re-do later..
Also id recommend not getting the KLM wire, go straight for the kolossus fleks kable. I know $3.40/ foot seems expensive, but its worth it.
Just my .02 but its your system bro :)
hes rite i didnt even notice you said you have a stock 80 amp alt!!! you need a HO alt or a battery, i would go with the new alternator
-Car: 2006 Ford expedition King Ranch
-Subs: 2 FI BTLs 18 fully loaded
-amps: 2 sundown SAZ 3000D
-Alternator: DC Power 260 amps
-Batterys: 2 optima yellowtops
-A whole shit load of 0 guage knu hyper flex and raptor cable
-Rockford Fosegate 3sixty
Even at 2KW you can do 4 guage all around easily, but it is worth it to do 1/0 for "big 3". Would go 1/0 after about 2,500w for sure though.
Hammerdown... 1%
okay if i got a ho/o alt would it be fine if i stuck with my stock battery for a while?
http://www.maniacelectricmotors.com/hiou140amp19.html (tell me what you think about this alt, i never heard of the brand.)
thanks.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
That alt looks too expensive for the output to me.. a small case GM might fit?
Hammerdown... 1%
dc power engineering ftw
o gauge no matter what
if i got me one of those alts, can i keep my stock battery for while?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
