My Viper 5701 wont respond back to the 2 way fob. I have tried disconnecting the vehilce bat, pulling the 15 amp fuse, all 3 30 amps, tried a new antenna cable and antenna, tried using a 10k ohm resistor wired within an inch or 2 from the brain on the blue antenna wire, deleting the remotes, relearning them. Still nothing.
All the functions of the remote work just fine as a 1 way but I get the out of range error tone and flashes. What to try now?
Truck 1 96 Silverado Ext cab
4 JL w6v2 12"s
2 JL 1000/1's
2 sets of JL XR components
RF 4 Chan
Blowthrough
141.5 @ DB drag street max 3-4
148.8 outlaw.
Truck 2 silverado 2500HD Ext Cab- Building this truck now
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
Subs under rear bench lifted 4"
Did you try putting new batteries in the remote?
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
Its a new system. Just installed on sunday. So less than a week. Plus the range is pretty freakin far. I started the truck from 1/8th mile away inside a brick building. I put the bats from my wifes remote in and no luck either. But she had 1 large 3 volt and mine has 2 smaller 3v. Not sure if that makes a dif.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
how many topics you gonna keep making about this ?
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
I moved this here after i noticed i was still in the general AUDIO section. Which was my fault so I moved it here. I know when I am looking to help someone out the I prefer for it to be in the right section. Plus I figured there are some people out there that live in certain sections, Like some only liik at the interiors or wheels or whatever. Might be some actual techs that migh only lok in the proper sections.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
i would definitely try the 2 3 volt batteries. It is a 2 way remote and would use more voltage to transmit ( I am assuming). Good luck.
God damn its hot today. My balls are stuck to my leg.
an alarm is only as good as its install. just saying.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
im pretty sure youve checked this, but i gotta ask..... youre sure youre using the 2way remote? those systems come with one 2way and one 1way...... like i said, im just making 100% sure.....
2003 Toyota Sequoia
Pioneer 4100dvd
Memphis PR6.5 3ways in all four doors
Memphis PR 15s (4)
Memphis PR 1.1000 (2)
Memphis PR 4.50 (1)
Optima Yellowtop (2)
Viper 5901
8000k H.I.D. kit
15% tint (2layers)
We have doublechecked install. All wires soldered and insulated. Even insulated the fuses to prevent any type of arc and to secure them in. The problem is the 2 way feature only. This is a common problem with these alarms but the common fixes arent working. I am going to assume that the problem is the actual remote. The 1 way is perfect and this alarm is great as a 1 way except the annoying communication failure it sends back.
4 JL w6v2 12"s
2 JL 1000/1's
RF 4 Chan
Blowthrough
148.8 outlaw.
4 RE SE 10"
JBL BPX 2200.1
Soundstream 4 chan
JL XR comp
RF 3 ways
