Miakehl Posted February 7, 2010 Report Share Posted February 7, 2010 I'm trying to decide on the subs for the next build stage of the Buick. And I'm stuck between the 8500s I have and Fi's BL series 12s. Quick specs: MTX T8512-04 Fs: 36.35 Hz Qms: 3.16 Cms: 0.083 mm/N Mms: 230.47 g Rms: 16.66 kg/s Vas: 1.287 ft³ (36.45 liters) Xmax: 0.850 in (21.59 mm) D: 10.500 in (266.70 mm) Sd: 86.59 in² (558.65 cm²) Vd: 73.61 in³ (1.21 liters) Qes: 0.72 Re: 3.21 O Bl: 15.33 Tm Prms: 500 Watts (Bullshit will take 750rms easy) Qts: 0.580 ??: 0.234 % SPLo: 85.90 dB SPL 2.83V/1m: 89.78 dB Fi BL 12" DUAL 1 | DUAL 2 Fs: 35.2 Hz | 39.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 4.68 | 4.72 Qes: .25 | .25 Qts: .24 | .24 Mms: 212g | 212g Cms: 0.96mm/N | 0.96mm/N Sd: 480cm^2 | 480cm^2 Vas: 31.2 l | 31.2 l Spl: 89.1dB 1W/1m | 89.1dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm Rms: 1000W * | 1000W * Sealed box: N/A cuft | N/A cuft Ported box: 1.5-2.5cuft | 1.5-2.5cuft Sub OD: 12.500” | 12.500” Cut ID: 11.125” | 11.125” Mounting depth: 6.750” | 6.750” Displacement: 0.18cuft | 0.18cuft What do? The price for the new subs is not an issue I'm going for SQ more than SPL, but I still want loud. Suggestions? [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4 Link to comment Share on other sites More sharing options...
Steph3n1 Posted February 7, 2010 Report Share Posted February 7, 2010 I'm trying to decide on the subs for the next build stage of the Buick. And I'm stuck between the 8500s I have and Fi's BL series 12s.Quick specs: MTX T8512-04 Fs: 36.35 Hz Qms: 3.16 Cms: 0.083 mm/N Mms: 230.47 g Rms: 16.66 kg/s Vas: 1.287 ft³ (36.45 liters) Xmax: 0.850 in (21.59 mm) D: 10.500 in (266.70 mm) Sd: 86.59 in² (558.65 cm²) Vd: 73.61 in³ (1.21 liters) Qes: 0.72 Re: 3.21 O Bl: 15.33 Tm Prms: 500 Watts (Bullshit will take 750rms easy) Qts: 0.580 ??: 0.234 % SPLo: 85.90 dB SPL 2.83V/1m: 89.78 dB Fi BL 12" DUAL 1 | DUAL 2 Fs: 35.2 Hz | 39.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 4.68 | 4.72 Qes: .25 | .25 Qts: .24 | .24 Mms: 212g | 212g Cms: 0.96mm/N | 0.96mm/N Sd: 480cm^2 | 480cm^2 Vas: 31.2 l | 31.2 l Spl: 89.1dB 1W/1m | 89.1dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm Rms: 1000W * | 1000W * Sealed box: N/A cuft | N/A cuft Ported box: 1.5-2.5cuft | 1.5-2.5cuft Sub OD: 12.500” | 12.500” Cut ID: 11.125” | 11.125” Mounting depth: 6.750” | 6.750” Displacement: 0.18cuft | 0.18cuft What do? The price for the new subs is not an issue I'm going for SQ more than SPL, but I still want loud. Suggestions? Id do an Fi q then. the BL is a more spl sub i have one it still sounds good tho 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
Miakehl Posted February 7, 2010 Author Report Share Posted February 7, 2010 Id do an Fi q then. the BL is a more spl sub i have one it still sounds good tho Yeah, they come out right about when I plan on starting the hardcore stuff on it so that might work. Any word on the RMS power rating? I want right at 1000. The website doesn't say. Edit: Wait, the site says Mar012010 but people already have them? lolwhut? [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4 Link to comment Share on other sites More sharing options...
R_Mac_1 Posted February 7, 2010 Report Share Posted February 7, 2010 Seems like they're changing the subs up a bit. The Q, BL and SSD say coming in March. Pretty sure the Qs were 1000 watt RMS as well, they were just geared more towards SQ than the BL was. 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M Link to comment Share on other sites More sharing options...
Miakehl Posted February 7, 2010 Author Report Share Posted February 7, 2010 Seems like they're changing the subs up a bit. The Q, BL and SSD say coming in March.Pretty sure the Qs were 1000 watt RMS as well, they were just geared more towards SQ than the BL was. Cool, then than pretty much what I'm going for. [HOONIGAN]* '01 Ford F-250 LWBJVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4 Link to comment Share on other sites More sharing options...
!!!BLINKY!!! Posted February 7, 2010 Report Share Posted February 7, 2010 The only problem is with FI is after you buy the subs and when something happens are they gonna be there with it blows and you need parts, i heard FI was haveing problems getting parts for there subs... Dont hold me to this just heard this from a compeditor friend of mine who uses FI.. Blew his 18 BTL and had to wait almost 6 months for recones.. and when he got them he said it was RE products.. But they were once the same company.. But FI is a hell of a sub just the service isnt so great... HU...Pioneer 5900IB Wireing...Stinger Amps...(1) Modded Stetsom 2K6.. Batts...(1) Stinger 2150 SPL Subs...(2) DD 9515 Hybrids Daily Subs..(1) Mmats P3.0 15 N.S.P.L. 2012 NC State Record Trunk 1801-3600 2012 World Record Trunk 1801-3600 2011 NC State Record No Wall 0-24" 2011 NC State Record No Wall 0-24" Hardcore 2011 World Record No Wall 0-24" 2011 World Record No Wall 0-24" Hardcore 2010 World Record No Wall 0-2500w 2010 NC State Record No Wall 0-2500w 2009 NC State Record No Wall 0-24" 2009 NC State Record No Wall Hardcore 0-24" Link to comment Share on other sites More sharing options...
St.Ides Posted February 9, 2010 Report Share Posted February 9, 2010 The only problem is with FI is after you buy the subs and when something happens are they gonna be there with it blows and you need parts, i heard FI was haveing problems getting parts for there subs... Dont hold me to this just heard this from a compeditor friend of mine who uses FI.. Blew his 18 BTL and had to wait almost 6 months for recones.. and when he got them he said it was RE products.. But they were once the same company.. But FI is a hell of a sub just the service isnt so great... FI now sells recone kits Directly from their website. TNCB ....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra? Link to comment Share on other sites More sharing options...
jesterjames Posted February 10, 2010 Report Share Posted February 10, 2010 Fi = AA = Scott making the subs Pioneer 500UB 1 LVL4 15" 4.3cubes tuned to 35HZ BXi1606D 1/0 Red top in back JBL 5 1/4's front Infinity Kappa 6 1/2's rear 145.7 Legal on music New Audio Control Link to comment Share on other sites More sharing options...
Gotloud555 Posted February 11, 2010 Report Share Posted February 11, 2010 MTx are good stuff, but i would have to do with FI Bl because those sub go get loud and lows. What great about the Fi Bl, it can be recone.. Not sure if that mtx can be recone.. Link to comment Share on other sites More sharing options...
