Landon Posted February 7, 2010 Report Posted February 7, 2010 I have a 15in svc 4ohm sub that 450rms and 950peak and im wondering what kind of amp i should get??? Idk what to do im new to this so if anyone has an idea it would help so much!
Ndnkobra Posted February 7, 2010 Report Posted February 7, 2010 An SVC 4 ohm sub means you can only wire it to 4 ohms, for budgets sake, you can buy an AQ1200D. Its a 1200W amp @ 1 ohm, but its 510W @ 4 ohms @ 14.4V. So assuming that electrical stays around 13-14, your sub should be safe. Its about $250 for the amp, which is pretty good, plus if you ever decide to go bigger you'll have an amp that can deliver power at lower impedances. Hope that helps!
Landon Posted February 8, 2010 Author Report Posted February 8, 2010 An SVC 4 ohm sub means you can only wire it to 4 ohms, for budgets sake, you can buy an AQ1200D. Its a 1200W amp @ 1 ohm, but its 510W @ 4 ohms @ 14.4V. So assuming that electrical stays around 13-14, your sub should be safe. Its about $250 for the amp, which is pretty good, plus if you ever decide to go bigger you'll have an amp that can deliver power at lower impedances. Hope that helps! Yeah I see good things about AQ's and I will for sure be going bigger in a few years but I heard about bridging a amp to 4ohms?? Could that work for my sub? Thanks
mhart Posted February 8, 2010 Report Posted February 8, 2010 just get a cheap RF amp, then use it for highend later. '00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dBTeam DC Team XS Power Team ISB Steve's Body Shophttp://www.dcsoundlab.com/
Austin175 Posted February 8, 2010 Report Posted February 8, 2010 i got a hifonics colossus for sale kia spectra 4 door HU-a kenwood kdc-692x optima red top under the hood ( kinetik battery or powermaster in the back ) Iraggi 260amp H/O alternator 1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming ) front speakers - back speakers - 2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future) Sundown 3500d( going to be 2 sometime ) i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
teamjeffrey Posted February 9, 2010 Report Posted February 9, 2010 i would say incriminator audio 20.1 it does 1,600 at 1 ohm 450 at 4 ohms you can get the amp straight from company people who have bought from me Team Bassick (ALPINE) Purplehaze nidus head unit sony dsx-s310btxsubs 2 12 incriminator audio king of basssubs amp incriminator audio 20.1mids/highs mids/highs amp incriminator audio 6.4equalizer clarioncrossover interfirealternator 1 mechman 240ampbattery's xs power 1 d2100 2 d3100sky high car audio 1/0 awg ofc wires memphis car audio 1/0 ofcxs power xs flex 4 awg sky high car audio 8 gauge ofc sky high car audio 12 gauge ofc t spec rca check out my building log http://www.stevemead...frey-build-log/http://www.stevemead...d-other-things/check out audio gear i have for salehttp://www.stevemead...51#entry1595151
Landon Posted February 9, 2010 Author Report Posted February 9, 2010 All these amps you guys talk about look good but are kinda expensive and I wouldn't be doing hardcore upgrade for a few years so I'm wondering what are my other options?? And is it bad to have a 4ohm 8ohm sub(s) because I'm not getting the jist of how an amp relates to a sub like ohm load and bridging and channels...hahaha sorry I'm a retard to this
z71kris Posted February 9, 2010 Report Posted February 9, 2010 you're not retarded, you're new....theres a differnce..here is some reading for you on ohms law..http://www.the12volt.com/ohm/ohmslaw.asp..read it, understand it, learn it....also remember you can buy a cheap amp that puts out 1000w, but it will be power hungry, and have to run 14 v to get there(if it ever does), or you buy a good amp that will consume a lil less power, and put out better power and perform better... 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
SATX-Extemebass254 Posted February 11, 2010 Report Posted February 11, 2010 I really like Arc Audios Arc mini 500.1. Good clean power that would do nicely with that sub. Not to mention its size. Its sexy
