XS Power
XS Power Battery Wattage Guide
okay so i have a dc power 320amp alt w/ 15.1 regulator a d3400 in the front and one d3100 in the back and im planning on running 2 bc3500ds and my 3 mb quart amps for highs n mids.. how many more d3100 will i need to not worry about anything going wrong..?
MURDERD HONDA PILOT!
Looking to see how many watts I can expect out of a d1600? I havent found what you're rating them at. Will be for mostly daily with competing several times a month.
1500 watts competition and 3000 watts daily use.
First i would watch the 15.1V continous charge voltage. 4 D3100 total would give you no worries, but you could probably get away with just one more.
Nathan,
Getting ready to order some xs power batteries to replace my Optima's.
Ordering a dc power 270a alt and was wondering will a d3400 up front and 2 d3100's be adequate to support 2 saz3500's ran at 1ohm and a sax100.4 ran active
For a mix of competition and daily use...
great vid Nathan...tough ass batteries..the D 3100 didnt want to drop out of 11 there for a while haha
NoFearX18 said:
trainman0978 said:
I have 1 5100 and 4 1200s.. I rest at 12.8-9.
Charges at 14.7-15.0
When I turn the car off it rests at 13.2 and trickles down to 12.8 or so... Are these all optimal voltage levels? I was considering buying a charger but if these are where they need to be then there's no point...
Edited by Rainman215
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Nathan,
You would be good for daily use, but I personally would run 3 D3100 in the back at least for competition use. You are going to be pulling more than the alt can produce, so you will be pulling straight from the batteries while doing demos and comps. I like to have a lot of reserve, so the voltage will stay up and not make the amp work so hard.
That is pretty good for the batteries hooked up in the car. I will say though you will extend the life of your batteries if you charge at least once a month with a good charger.
  • 1 month later...
I'm wondering what battery would be best for my setup. I have a 600rms watts pioneer amp right now and am going to add an AQ1200D with 1200 rms watts. I was gonna do the big three but wasn't sure what battery to get in addition to the one under the hood. I have a stock 120 amp alt and also wasn't sure how to wire everything thanks!
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
  • Who's Online   0 Members, 0 Anonymous, 580 Guests (See full list)
