SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 the amount of reserve doesnt matter if you cant properly charge it! youre getting low voltage because youre asking too much of your alt. small sedans dont create a great amount of power! if you had a sufficient power supply (alt), you wouldnt see voltage drop. hhhmmm makes since... but still a brand new battery just dropped it in and getting low volt?
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 all that equipment and no volt meter lameAnd i agree, 0 gauge grounds for starters and go from there i know i do need a volt meter i was going to buy a junk cap of craigslist then do like EXO did and make a volt meter out of it
SVT4LIFE Posted February 9, 2010 Author Report Posted February 9, 2010 did you ever check the impedance of each channel? you could have had each channel to low for your mids/highs amp no i dont know how to do that but the doors sound good now its my low volt cut out on jl 1000/1V2
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 check all connections to amps and check power connections with a DMM. what would this do? how would this help with my low volt cut out on JL amp like i said its all new basicly i just ran all the zero gauge and 4 gauge and all new fuses and grounds and batterys
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 Thats so messy to read im not even going to try.Have you done the big 3? How are the amps and Batterys grounded? i havent done the big 3 dont i need new battery terminals for that? im not sure how to do the big 3 dont you replace the ground on alt replave the ground on battery terminal and like some ground to motor or something idk
Skullz Posted February 10, 2010 Report Posted February 10, 2010 A. Big 3 in 0/1 up front. B. 0/1 Ran from front to back fused at both ends to each battery. C. Then run 0/1 to the distro block from the battery for the amps. D. Run all wires to the respective amps. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 did you properly set the gains with a DMM or oscope?and i re read it, i didnt see where you said you did the big 3 to help voltage issues, that should be done as well.. maybe im just tired and didnt see it no i havent done the big 3 maybe that will help?
dugee81 Posted February 10, 2010 Report Posted February 10, 2010 hhhmmm makes since... but still a brand new battery just dropped it in and getting low volt? did u give the alt a second to charge it fully? take it out on the highway without the stereo on for a min see if that helps 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Team_DC-Derrick Posted February 10, 2010 Report Posted February 10, 2010 well, go get some 0g and do the big 3 http://www.stevemeadedesigns.com/board/ind...showtopic=13280 thats the tutorial go get a DMM and set your gains with I posted everything you need to do... The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
SVT4LIFE Posted February 10, 2010 Author Report Posted February 10, 2010 A. Big 3 in 0/1 up front.B. 0/1 Ran from front to back fused at both ends to each battery. C. Then run 0/1 to the distro block from the battery for the amps. D. Run all wires to the respective amps. no big 3 yet... front yellow top + term zero gauge to a 250 anl fuse block then zero out the other side of fuse block then zero to the back to a fused dual anl distro block then from other side of fused distro 2 sets of 4 gauge one set of 4 gauge go's from distro to a kinetik hc800 then on the kinetik theres a zero gauge ground on neg post that go's to body then 4gauge ground off neg post on kinetik to the jl 1000/1v2 then on the pos term on kinetik is 4 gauge coming from distro block then 4 gauge back to jl amp the other 4 gage from disrto block go's to the arc audio door speaker amp so 4 gauge in to the arc amp and 4 gauge ground out of arc amp to the body
