OK, so i had some time to work on my yukon today...BUT my camera wasn't charged at all, i started to charge and took some pics then it died so i only have a few.
well i was going to reduce my ports by 1" to lower my tuning although i figured i would try something else.
what i did is I added a layer of 3/4" to port and to make up for the other 1/4" i am going to put 45's in the corners of my ports, so sorta like a widened octagon is what it is like now that and also flaring my port by cutting the top side at a 45* then going at it with a grinder so it is like 1.5-2" radiused :spiteful:
need to go buy some fiberglass mat tomorrow and finish that up by Wednesday if i can, i will post some pics of this tomorrow or wed. if i get a chance.
As for today here are the pics of my wiring and some of the fuse holders in
here you can see the 4 1/0g power wires and 4 ANL fuse holders mounted on inner fender well
from other side you can see the 3 1/0g grounds
close-up of fuse holders
coming through inside
making sure they aren't twisted or crossed
front side tie strapped
rear tie strapped in
I also have ground going directly to frame and in rear going through under yukon(i'll take pics of this tomorrow-easier to understand that way)
i wanted to take some more pics but i just charged camera enough to get these and it died again, maybe more tomorrow...
so uhm.. is that enough wire :yahoo:
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
looking good,keep up the good work.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
very nice keep pics coming
i plan to but i think the battery in my camera is messing up, it is barely holding a charge :sorry: , i charged all night so tonight i might try and take some more pics
1996 GMC YUKON 2dr
Eclipse cd5000
ok just a qhick update, i started fiberglassing in 45's in my port and already added .75" to one side of them, but i haven't been out to take pictures or get more work done because it has been snowing all last night and today.
once it warms up i will get back to work, but for now break time :tease:
and to just give an idea of how anps are going to be mounted (i think) they will be under the are that i had my batteries hidden in before which was behind where my old fosgate amps were
So what do you guys think?
1996 GMC YUKON 2dr
Eclipse cd5000
lookin good how about some vidz of it playin when its all back together lovin the ss build my buddys shop did a durango 4 T5 twelves on two pca2000d in a clamshell it knocks
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
IMO.... Just take a few days off so we can see some more...... More Pics, More wire runnin...
On the topic of wires.... are you soldering them or Hammer Crimpin 'em?
Waiting for :hairtrick:
Keep up the GREAT work
Steven
Does this smell funny to you? Its your sister :roflmao:
Steven
i have a set of huge wire crimpers i got from work, they are like $250 bucks and are supposed to be precision crimpers( they are for crimping hundreds of thousands of dollars of cable that we have to splice what looks like 3 1/0g conductors that that take an hour and a half to complete... and cost our customers about $1000 per splice :huh:
but i brought a set home and they work great!!!
i will post some pics later of what their crimp looks like.
As for this time i went ahead and soldered them but i know if i am going to continue soldering.
where i work...or worked, we would get back cable with splice that were there for sometimes 8-10 years, and the solder was always corroded to where the crimped copper was in perfect condition when we disassembled and inspected them.
plus i know it takes ALOT of heat but i am still worried in the back of my head about the solder coming loose with heat and vibration.... and i know the crimps do not come loose i have pulled over 12,00lbs with a forklift and crimped solid copper #1 cable for about 20 feet and the cable busted and never pulled apart a crimp :D
1996 GMC YUKON 2dr
Eclipse cd5000
