Guest Scylloga
When it turns your skin white that means its killing the skin. Nothing to bad to worry about. Just be careful while using it and dont inhale as some others have stated. If you ever walk pas the asian nail shops and smell something funny its the acetone they use. It has a very strong odor so people know they are inhaling it. That is also why they wear the masks so it helps filter out the fumes. Also you pop is right put some gloves on cause once your his age you might regret it. Who knows what the world will be like it 20 years?
My ex wife worked at a electronics manufacture that used acetone to clean the parts and they had a very powerful exhaust system to help keep people from passing out from the fumes.
Woke up this morning, all back to normal.
/thread.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
Did you test it on your car yet to see if turns white?
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
lmfao, I'm not retarded.
It will strip the paint. That's the main reason I was asking if there were safety concerns for skin contact.
:01nocomment8so:
2015 Mazda 6
if you start to see a third arm sprouting from your back, you should probably go to the hospital.
God damn its hot today. My balls are stuck to my leg.
Will do, captain.
