rubbernutz1 Posted February 22, 2010 Report Posted February 22, 2010 need some advice on fusing. i am going to be running 2 , 140 alternators on my van. im just curious to know what size fuse i should put inline from the alternators to the batteries. Quote
Ndnkobra Posted February 22, 2010 Report Posted February 22, 2010 How much current can your power wire that you're going to use from your alt to your battery carry? Quote
bustedassblazer Posted February 22, 2010 Report Posted February 22, 2010 need some advice on fusing. i am going to be running 2 , 140 alternators on my van. im just curious to know what size fuse i should put inline from the alternators to the batteries. if this alternator lead is going to the battery under the hood then just curious to the need of a fuse at all Quote 1996 S-10 Blazer Kenwood DNX-6140 (2)Kinetik HC2000 (2)US Amps MD3Dv2 US Amps MD42v2 (4)Hertz HCX-165 (front doors) (2)Hertz HL-70 (dash) (2)Hertz HT-25 (dash) (2)Hertz SX-380D
rubbernutz1 Posted February 22, 2010 Author Report Posted February 22, 2010 im goign to use 0 gauge for the alt to bat lead. im using 2 alts and running 1 to the front battery and the 2nd to the rear batteries. whet my question is, is what size fuse fuse to use in the line going to the rear batteries. both atls are 140 amp for now. Quote
OrionStang Posted February 22, 2010 Report Posted February 22, 2010 Fuse it close to the rating of the alt, maybe a little higher. So, in your case a 150 or even 200 should be fine. 0 gauge will handle it easily. Quote SMD Super Seller My Feedback Thread
n8ball2013 Posted February 22, 2010 Report Posted February 22, 2010 Fuse it close to the rating of the alt, maybe a little higher. So, in your case a 150 or even 200 should be fine. 0 gauge will handle it easily. no thats not correct. The fuse is in place to protect the wire. If a wire has a max draw of 300 amps. use a 300 amp fuse. It won't hurt to use a lesser fuse though. most 1/0 gauge wire has a 300 amp rating CCA has a rating of 250 if my memory is right. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
OrionStang Posted February 22, 2010 Report Posted February 22, 2010 no thats not correct. The fuse is in place to protect the wire. If a wire has a max draw of 300 amps. use a 300 amp fuse. It won't hurt to use a lesser fuse though. most 1/0 gauge wire has a 300 amp rating CCA has a rating of 250 if my memory is right. I got that, but if the alt is only making 140amps, how will that wire ever see 300? Im still learnin all this electrical stuff. Quote SMD Super Seller My Feedback Thread
n8ball2013 Posted February 22, 2010 Report Posted February 22, 2010 it more than likely never will. thats why i said it wont hurt to fuse lower. if he is only pulling 140 amps then he could actaully get away with 4 gauge. he's overkilling the power wire why fuse it lower? Someone may see it differently than I do though. I'd put a 300 in it or not bother doing 1/0 guage. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
OrionStang Posted February 22, 2010 Report Posted February 22, 2010 (edited) Yeah, I thought about that wire size, too. So anywhere btween 200-300 fuse would be safe, right? Edited February 22, 2010 by OrionStang Quote SMD Super Seller My Feedback Thread
rubbernutz1 Posted February 22, 2010 Author Report Posted February 22, 2010 im planning on upgrading the alts in the future to 200 amps each. thats why i am going to use the 0 gauge Quote
