Is there anyway to hook up a second subwoofer to a surround sound, it would be a phillips surround sound?
if its an all in one home theater system then normally NO due to the fact that the internal amp usually drives the sub...if the main has an audio out then you could add a powered sub as long as hit has a low pass built in
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(4)Hertz HCX-165 (front doors)
(2)Hertz HL-70 (dash)
(2)Hertz HT-25 (dash)
(2)Hertz SX-380D
Thanks man.
2001 Dodge Ram
i just replaced my sub in my philips setup
just replaced the 8 to a 12" mtx blue thunder
the 8 is a 3 ohm sub and the 12s single 4 ohm so it works great and sounds good no more bottoming out little sub
R.I.P!
(Nov-29-2009)
92 explorer
current build
didnt even consider that option...had my blinders on i guess..hell with that approach you could use just about any efficient home audio oriented woofer
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(2)Hertz SX-380D
How would i do that, just get a self powered amp and wire it to the slot the subwoofer would usually go?
2001 Dodge Ram
if i were to go that route id build an enclosure for my sub with a good flat responce that would drop to the bottom octave...then just run the speaker wires off the amp where the current sub is wired
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(2)Hertz SX-380D
that's what i would do too, or build an enclosure, that houses the sub and the amp that the other enclosure has
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Just make sure the impedance load is at or above what the receiver is stable at...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
EXACTLY...those all in one home theater setups usually dont have a protection circuit on the amp output stage..itll just blow that channel..i dont know how many guys i saw in highschool ruin equipment by just adding speakers
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(2)Hertz SX-380D
